Installed amp, now charging system doesn't work and code p1516
Old Jun 5, 2015 | 02:39 PM
2K Silvy's Avatar
Default Installed amp, now charging system doesn't work and code p1516
I did it, finally got the wire run, tied in behind the fuse and had music...then I started the truck and it said charging system issue. I went and got a scanner that pulled code p1516 which is apparently reduced engine power. I'd assume this is because of low voltage.
I took a multimeter to the alternator and it didn't show anything. I am a little ticked. This is a 2011 silvy ltz with 35K miles...it shouldn't have these issues.
Anyways I kinda need my truck for the weekend so if anyone has any ideas as to why the charging system would stop working please PLEASE give any and all advice. I really have no idea where to start, all I did was pull off the positive terminal...Nothing else was touched.
Old Jun 5, 2015 | 03:47 PM
treylittlefield's Avatar
I would pull it straight from battery with a separate fuse and see if it changes anything.
Old Jun 6, 2015 | 01:22 PM
gamble686's Avatar
How big is the amp? Power wire gauge? Big 3 upgrade?
ARC
57
Feb 21, 2022 10:54 AM
lxcoupe
Jul 21, 2015 02:12 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
GreyChevy
Jul 7, 2015 08:57 PM
