P0332 - Do I have to let this kill my track plans?
Old Apr 19, 2010 | 11:57 AM
  #21
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by Sc00by
My rear knock sensor went out last year with the same code. Mine definatly pulled timing and I definatly felt a difference. What happeds with these knock sensors on our LS engines is MAJOR corrosion issues. People who wash and detail their engines on a regular basis will have this problem. Because the knock sensors are located below a cheezy plastic cap under the intake water will seep in and pool up in the knock sensor cavity. It mainly affects the rear sensor but if your changing them you might as well do both. The harnes can become corroded as well. If its messed up change it. Mine was alright so its still installed without any problems. What I did to hopefully prevent this from happening again is use RTV and built a dam to block water from going into the cavity. Its about 1/2"-3/4" tall and wide and wraps about half way around the sensor. Its worked out great and have had no problems since.
Yep, there's a TSB that outlines building the dam of RTV to help prevent future water intrusion and corrosion
Old Apr 19, 2010 | 03:57 PM
  #22
joeyc125's Avatar
11 Second Truck Club
Originally Posted by Evil Eric
I just read a comment from another member in the diagnostics forum that said that this code causes the computer to pull a constant 4* of timing. Ive got this exact code and I see 0 knock in my logs and the truck still runs great. Ill change it later in the summer when i get bored.
It won't necessarily show as knock retard, but if you look at you actual timing you will see it is lower than usual, depending on your low octane table.
Old Apr 19, 2010 | 04:31 PM
  #23
DV2000NJ's Avatar
13 Second Truck Club
Intake manifold is off, knock sensors are out, I'm too hungry to do anything more before dinner.
The rear sensor was literally submerged. Probably 2.5" of water in there.
Old Apr 19, 2010 | 04:48 PM
  #24
TIM Z's Avatar
11 sec. Truck Mod
Man that sucks.
The salvage yard had pressure washed my 6.0 too i saw. I wasnt too happy about it but didnt think any more of it till now.
When pull the manifold to put the blower on i will double check mine. Thanks for the heads up.
Old Apr 19, 2010 | 04:55 PM
  #25
DV2000NJ's Avatar
Yeah definitely check. My dumb *** didn't when I had the manifold off.
At least when you pull yours off, a "more fun" manifold will be going on.
Old Apr 19, 2010 | 05:02 PM
  #26
TIM Z's Avatar
11 sec. Truck Mod
It would be more fun with your trans!!!
GMCtrk
Jan 27, 2016 06:47 PM
06 4.8
Sep 11, 2015 10:36 AM
Justin87gn
Sep 10, 2015 12:06 PM
iregret
Sep 7, 2015 01:20 PM
Cowboy Tom
Sep 5, 2015 04:29 PM
