OK I`ll bite LSx for a Torquer instead of a BBC.
Old Jan 9, 2009 | 09:58 PM
jsawduste's Avatar
Default OK I`ll bite LSx for a Torquer instead of a BBC.
Going back to this recent thread; Educating me on the merits of the LSx engines.
https://www.performancetrucks.net/fo...=432189&page=2
You folks made some great arguments on the LSx vs. BBC.
Understanding the advantage of the more modern technology of the LSx series.
How would you make a low rpm torque monster for towing ? NA only no FI.
Say 2000 rpm cruise with 7000 in tow ?
Old Jan 9, 2009 | 10:13 PM
budhayes3's Avatar
PT's Slowest Truck
Torque monster...take a 6.0 block and stroke it, from what I've seen the 408's have gobs of torque
Old Jan 10, 2009 | 05:43 AM
BigCountryx's Avatar
I don't get all this BB talk, if you want an "easy" big cube swap, go LSX with ~440 cubes and still leave room for a rebuild. Lots of cubes and still have room to rebore later. I think upwards of 480+ cubes is possible on the standard deck height for N/A. IMO
Old Jan 10, 2009 | 06:01 AM
TurboGibbs's Avatar
Or go with the tall deck.
4.25 bore and 4.50 stroke and you've got your 572!
You could still use your stock ignition and computer system. Not sure what they are doing with the intake on a tall deck. The LS7 with custom spacer plates or a sheet metal i'd imagine. Remember, there is no water going through the intake and the valley has it's own cover as well.
http://www.gmperformanceparts.com/En...6454&engCat=ls
Old Jan 11, 2009 | 02:54 AM
silver-mod-o's Avatar
Hunt&Fisherator
572ci "small block"
If you'd have said anything like that 15yrs ago, you'd be recommended for professional help....
You want tq monster?
That thing eats 10bolts and ***** 4L60's
Old Jan 11, 2009 | 03:03 AM
Mangled03gmc's Avatar
Baltimore Whore
im not saying in all cases but most, esp for street apps, even smaller cubic inch, can atain what a carb BBC can make, do it more efficiently.. As you have seen the lsx is a bad *** motor, hard to beat..
Old Jan 11, 2009 | 08:03 PM
jsawduste's Avatar
Hmmm, that WOULD be a BA setup. Hopefully GMPP puts a part number on this block soon. Anyone want to guess when they will be avaliable ?
I can make up LS7 spacer plates.
Using the stock ignition/ECU would be a plus.
Did see the LSX454 also. Wonder if there would be room for a longer arm and a bit of bore ?
Old Jan 11, 2009 | 08:15 PM
litreddevil's Avatar
Banned
you can take an 05 and new 6.0 block and go to a 434 all day.i think the block the can go larger than 454 is the warlock block not sure and i think the biggest they go is 510ci.
TrendSetter
Nov 26, 2018 07:18 AM
Three6GMC
Oct 27, 2015 08:04 PM
racedad70
Sep 16, 2015 01:51 PM
omc8
Aug 10, 2015 10:39 PM
