NGK TR6 plugs and performance wires
Old Sep 16, 2007 | 03:02 PM
Champion201's Avatar
Default NGK TR6 plugs and performance wires
Would I benifit from upgrading to the colder NGK TR6 plugs and some performance wires? I do have a Westers Hot Tuned PCM but other than that I'm basically stock. Will they help or hinder performance or basically do nothing at all?
Should I just wait a couple months until I get my Radix to upgrade these items?
Somebody please school me.
Thanks
Old Sep 16, 2007 | 03:29 PM
Stoichiometric's Avatar
I would put the tr6's in when you do the Radix. It won't hurt to do them now, but you won't gain anything either. The wires are nice to have for heat resistance if you have headers, they also will not help or hurt you performance wise.
Old Sep 16, 2007 | 05:13 PM
ranwalk's Avatar
Do the plugs when you do the Radix.
Pass on the plug wires, money better spent elsewhere.
Old Sep 16, 2007 | 06:47 PM
Thanks guys. I was kind of thinking I wouldnt gain anything with my present configuration but figured I'd ask some people "In the know"
Old Sep 16, 2007 | 06:50 PM
TouchOfEvil04's Avatar
Not to hijack but what are the stock coils rated to handle? Power level wise....on 99 +
Old Sep 16, 2007 | 06:52 PM
nightrunner's Avatar
Mr. Obvious
parish has stock coils....
the trucks have the most powerful coils out of all gen3 motors
Old Sep 17, 2007 | 02:43 PM
allenmehrer's Avatar
would the colder plugs prevent any engine knock by reducing any pre-ignition due to the heat from a hot plug? would u see any benefits on an engine already pushing the limits on advanced timing?
could u run more timing on a cold plug because ignition will occur more precisely from the spark not any hot spots found on a hot plug?
thanks guys
Old Sep 19, 2007 | 11:21 PM
anybody on this? thanks
Old Sep 22, 2007 | 10:08 PM
parish8's Avatar
single digit dreamer
thanks guys
i like to run the hotest plugs i can. the colder the plug the worse the idle and you can have a low rpm miss.
stock heat range till you boost it or spray it. 6's up to 150shot or ~10psi. maybe a step colder if you push it harder that that.
ARC
57
Feb 21, 2022 10:54 AM
sauldgold
Jul 23, 2015 02:15 PM
cbhedrick
Jul 20, 2015 10:12 PM
4B11T
Jul 13, 2015 03:48 PM
