new guy needs motor help. possible vacuum leak?
Old Feb 11, 2016 | 01:01 PM
MARCYTECH's Avatar
Registered User
Default new guy needs motor help. possible vacuum leak?
hi guys. first of all im new. my name is marcel and im from southern california.
im having an issue with my truck and coming here to ask for suggestions.
i have a 2007(classic) silverado with the 4.8L
my computer is tuned(hp tuners) to run off a speed density tune.
fuel system is not stock. aeromotive pumps and filters and FPR (all confirmed in working order.) no evap components.
everything has been the same for a little over a year with 0 issues
the problem:
i got a CEL for a bad knock sensor. replaced it and thats when my problems started.
when i start the truck cold it starts and runs PERFECTLY fine. no problems at all.
when the truck is at operating temps or near them and i start it the idle will immediately rise to about 2000 then drop to a somewhat lumpy idle. sometimes after putting in gear itll drop very low into the rpm range around 200-300. again these problems only happen when the engine is warmed up
things iv changed:
new intake gaskets
throttle body gasket
coolant temp sensor
smoke tested the intake (when the engine was cold) with 0 noticeable leaks
any body have any idea as to why this is happening? are there certain vacuum lines that are activated when the motor is running closed loop rather than open loop or vice versa? would an 02 sensor cause things like this?
thanks for the help. cheers
Old Feb 16, 2016 | 03:01 PM
MARCYTECH's Avatar
Registered User
no one has any ideas?
Old Feb 16, 2016 | 04:12 PM
DRAENOR's Avatar
Banned
First thing that comes to mind would be the EGR.
Suburbazine
Jun 15, 2017 05:38 PM
Mort
Mar 18, 2016 07:58 AM
Wrecker 426
Jan 9, 2016 09:31 PM
00buckshot
Jan 6, 2016 11:11 AM
mdwatts11
Dec 31, 2015 07:19 PM
