New brakes 911!!!
New brakes 911!!!
Hey all i need some help here I'm stumped... Just swapped my old OEM brake pads for HAWK Performance ceramic pads. Install went nice and smooth no issues but after test drive my rear brakes feel like my e-brake is applied (it isn't). its to the point where i can feel it slowing me down specially if i let off the gas, after a ride around the block i pulled into the driveway and noticed my rear brakes smoking! I already tried re-adjusting the e-brake. Any ideas????????
These are the pads:
Front:
http://www.summitracing.com/parts/HWK-HB323Z-724/
Rear:
http://www.summitracing.com/parts/HWK-HB324Z-673/
These are the pads:
Front:
Rear:
MASS seller approved
I just had the same problem check the slides that allow the caliper to slide away from the rotor if it can't move away the pad will always stay engaged or like someone said earlier check the caliper it could be frozen. Like I said I just did my brakes and it seem to always be braking and when I rechecked it was the slides were seized and the new pads had no where to go. With the old pads I didn't notice the slides because the pad was already worn were it made contact. I hope that helps. Btw I'd it is the slides autozone has replacement caliper brackets for 17.99 and then 6.00 for new slides
11 sec. Truck Mod
Did you use caliper grease on the caliper bolts?
Never use anti seeze on brake bolts, it will gauld up.
How did the new brake pads compare to the old ones?
Maybe you have a set that is incorrect maybe thickness wise? It could happen i guess.
Also did you cycle you E brake on and off a couple times to make sure its not sticking?
any fix for that other then buying a new one?
Pop the slides out of the little rubber boots and inspect them. They are probably bone dry and rusting. I know mine were. I had to clean them up and add some synthetic brake grease.
KINGCYCLES
10-02-2015 10:21 AM
