Need tire size recommendations
Old Dec 2, 2014 | 11:43 PM
Fueledx's Avatar
Registered User
Default Need tire size recommendations
I have a 99 ecsb and I'm crossed between running a 15x10 which from what I understand you need to grind the caliper down to fit? or a 17x9.5 both made by 1320 wheels. My buddy said I should run 29.5"+ tall of a tire but I can't seem to find any drag radials that big for the 17s. Any recommendations?
Old Dec 23, 2014 | 10:25 PM
bobfig's Avatar
imo run the 17" rims with 275/60-17 handkook rh06
Old Dec 23, 2014 | 10:46 PM
oakley6575's Avatar
Depends on if you are just wanting tires for a daily driver or a truck that will see the track. I would go to 15's so you are able to run a 30" tire if you are going to be hitting the track. I think you are stuck with 28" tires when running 17's.
I make the brackets to convert to 15's without grinding the calipers down. I run 15's daily on my truck now. My track tire is a 315/60-15 on a 15x10 wheel. I will be going with 295/65-15's next time for more leaf spring clearance.
Old Dec 23, 2014 | 11:14 PM
GMCtrk's Avatar
Run 390/45/17 M&H DRs on the racestar 17x9.5s
GMCtrk's Avatar
If you're not making significant power, you will be faster on a 28" tire more than likely.
Old Feb 21, 2015 | 08:50 PM
Fueledx's Avatar
Registered User
I didn't know there was such a thing send some my way I'd love to purchase some. how can I contact you"|?
southernsmoker
Aug 31, 2015 03:09 PM
maxspeed05V
Aug 12, 2015 06:29 PM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
kdw8888
Jul 9, 2015 10:52 PM
jrplz
Jul 9, 2015 12:07 AM
