Need oil suggestions for my 350
Old Jul 15, 2010 | 03:46 PM
1LOW4X4's Avatar
Banned
Default Need oil suggestions for my 350
This weekend I'll be assembling my 350 for my 85 silverado. It's had a boil, hone, new cam bearings. Ground crank, new bearings, aluminum intake, rebuilt carb, and all new fuel oil and water pumps, new pistons on old rods, new rings...
Basically all brand new ****. I am buying the small things tomorrow like plugs, dist cap and rotor, oil, coolant....
I need suggestions on oil. I run mobil 1 in my 01 silvy and my suburban. Should I run mobil 1 in this too? Or should I stay conventional?
If I should stay conventional, what brand an weight? Def don't want pennzoil.
For some background, this engine is goin back in my 85 silverado 3/4 ton lwb. It's got dual tanks and extra heavy duty suspension cause it's a camper king, designed to haul those bigass over the cab campers. So I need an oil that will stand up to the heavy duty use it's gonna get.
Old Jul 15, 2010 | 04:15 PM
meangreenburban's Avatar
Do NOT break it in brand new on synthetic. I like to run the first 3 oil changes with Valvoline conventional, then switch to what I'm going to stick with, which stayed Valvoline conventional. We always used 10W-30 for Chevy 350s in my family, and these trucks got worked out. Last 350 we had lasted a solid 240K miles of hard work without ever needing to be opened up. Honestly, regular oil changes with a good conventional oil will serve these engines well and keep your wallet happier.
Old Jul 15, 2010 | 04:47 PM
1LOW4X4's Avatar
Banned
I've heard good things about valvoline.
I've been thinking about staying away from synthetic on this motor.
Whats a good break in first oil change number on these older motors, 500 miles?
Old Jul 15, 2010 | 05:40 PM
Beatdown Z's Avatar
Laid Back
What kind of cam does it have in it? Flat tappet or roller?
Old Jul 15, 2010 | 05:44 PM
1LOW4X4's Avatar
Banned
flat tappet. The block numbers indicated that it was a later model block and roller cam capable, but didnt have the roller cam in it.
Old Jul 15, 2010 | 08:46 PM
budhayes3's Avatar
PT's Slowest Truck
Here's some info you might like:
http://cranecams.com/pdf/548e.pdf
http://www.joegibbsracingoil.com/?gc...Fcl25QodoGuajg
http://www.joegibbsracingoil.com/pro...kin/index.html
I've heard that you want high levels of zinc and phosphorus for engine break in for proper cam run in and ring seating
Slightly off topic, but I believe that Joe Gibbs is making Comp Cam's new Muscle Car Oil...I think it's a Gibbs oil with Comp packaging...
Old Jul 15, 2010 | 11:19 PM
1LOW4X4's Avatar
Banned
Checking those links now, thanks.
Meantime, anybody in the night crew have anything to offer?
Old Jul 16, 2010 | 02:58 AM
cdub81's Avatar
yes valvoline all the way. i run mobil 1 now but all my other trucks i have used valvoline and never had a single problem. castrol is a good secondary choice as well and all in a 10/30
Old Jul 16, 2010 | 04:05 AM
Parke10's Avatar
royal purple makes a "break in oil" and lucas makes a break in oil additive ,dont know much about em ,but might wanna check em out.
Old Jul 16, 2010 | 07:48 PM
1LOW4X4's Avatar
Banned
Well I finally got hold of my dad, his advice is to use store brand oil for initial startup, let the truck get hot for maybe 15-20 minutes, then drain it. Refill with conventional oil of your choice, drain at 500 miles OR LESS. The run the oil of your choice, which will prolly be valvoline.
I have the lifters soaking in some right now.
