Is my speedo broken or "uncalibrated"?
Old Jul 28, 2007 | 03:41 PM
ReSpAwN DeMoN's Avatar
Default Is my speedo broken or "uncalibrated"?
I don't know if speedo's are spring activated or if there is a computer circuit that keeps them in cal or what.
But last night I was sitting at a redlight and I noticed that my speedo was reading 60mph. As I acclerated the speedo kept track of my speed FROM 60. I turned the truck off and the speedo stays at 60.
Is this a simple fix or something expensive like the whole guage cluster? Is this a regular issue with all silverado's? or it just happens..
Old Jul 28, 2007 | 04:03 PM
ZZebes's Avatar
the needle is just chillin on the peg so in theory it can be spun but it is unusual, it sounds like the needle is turned
Old Jul 28, 2007 | 04:34 PM
regency's Avatar
mine done that the day i drove it off the lot and man was i pissed. they said its the cluster, it kinda looses track and they replaced it
Old Jul 28, 2007 | 05:02 PM
BlackGMC's Avatar
Resident Retard
mine did the same thing, I brought it to the dealership under warranty and they replaced it. They told me the electric motor that powers the speedo, sometimes goes out or sticks....
Old Jul 28, 2007 | 05:05 PM
so in theory I should be able to just gently manhandle the needle down to 0mph?
Old Jul 29, 2007 | 10:12 PM
regency's Avatar
just unplug the battery and it'll reset itself
Old Jul 29, 2007 | 10:37 PM
KySilverado's Avatar
Its the stepper motor in the cluster. Needs to be replaced.. Don't know about undoing the battery.... but if you just start/turnoff/start/turnoff it will eventually get back right.
Mine is doing the same thing. I'm going to buy a stepper motor (lots on ebay) and replace it.
Old Jul 31, 2007 | 04:02 AM
Kysilverado the motor definitly needs to be replaced?
It did correct itself. THe initial jerk of engine turn off got it back down eventually. Its been fine for about a day or so.
So its only a matter of time before it gets stuck again?
Old Jul 31, 2007 | 04:30 AM
Give it a few days and it will do it again and get worse.... probably and yes the motor needs replaced. There are places you can send it off to be done but if you are hand with a soldering iron you can do it yourself. Have to tear into the cluster. If you take it on yourself be sure and mark the positions of the needles before pulling them off.
RustyD
May 23, 2016 07:04 PM
gmcyukon
Oct 3, 2015 11:03 PM
Velocity1
Oct 2, 2015 08:01 AM
Jr. SXT
Sep 30, 2015 07:23 PM
trevorh1
Sep 27, 2015 08:47 PM
