is my reluctor wheel bad?
Old May 26, 2013 | 06:30 AM
Gadgetized's Avatar
Default is my reluctor wheel bad?
Size:  83.5 KBName:  20130524_184634-1_zps658686e4.jpg
My truck has been skipping progressively worse. I pulled the crank sensor out, and there are gouges in the sensor from the reluctor wheel hitting it. I started another thread and it appears there were problems with the sensor being too close, and hitting the wheel. It just doesnt look right to me that there is such a space between the plates of the new crank, and not the stock one. This is a new Eagle Crank.
Old May 26, 2013 | 08:13 AM
Gadgetized's Avatar
From searching around on the net, apparently there are 2 style reluctor wheels for the 24T. There was an early version that had the plates very close together, and a later version that was spaced apart. I am going ot try shimming the sensor away and see if that resolves the problem. Any other suggestions out there?
Old May 26, 2013 | 08:43 AM
whippled 8.1l build's Avatar
i do belive the cuts in the sensor are normal.. the 3 engines i have all have the same slight cuts..
have you put a new sensor in yet?
Old May 26, 2013 | 10:27 PM
Gadgetized's Avatar
I was unable to get a sensor today so I shimmed the old one out. Seems to be working fine so far.
OHsixLS3
Dec 27, 2016 09:30 AM
WhoAteMySoup
Aug 20, 2015 09:52 AM
OHsixLS3
Aug 10, 2015 07:19 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
Ketis
Jul 23, 2015 12:37 PM
