my ram air
Did some testing with a custom ram air setup. I gained a little over 2 tenths with it. I'll have to take a look at the time slips again but it gained almost 3 mph. Remeber, the faster you go the more power your going to make with a ram air setup. Well anyways heres all the pics that i know yall are wanting to see.
i have a similar set up with my truck...i ended up getting a scoop that a member custom made for the 03-05 silverados but it ended up working on my truck...
https://www.performancetrucks.net/fo...d.php?t=315183
so i ended up hookin the scoop up to a 4" dryer duct and getting a sewer adapter from home depot...you can kinda see the end result in this pic
i would defiantly recommend getting somethin to stop the 'larger' road debris from entering the box, i got some weird stuff in there like leaves or even cig. butts...i had picked up some nylon mesh/screen and put it after the scoop, its helps tremendously...also i recently put on a filter wrap to help with all the road salt and sand from the winter roads up here after realizing my filter was almost full of **** after a few weeks...since then no probs...
