My 07 Tahoe wont crank
Old 04-03-2009, 02:41 PM
JHALL7644's Avatar
Default My 07 Tahoe wont crank
Its been raining pretty good here and i hit a water puddle now my tahoe wont crank it just clicks and all my lights go off and my check engine light came on, i tried to jump it off and still wont do anything
Old 04-03-2009, 03:03 PM
Piss Pumps for Sale
Chevy Cowboy's Avatar
Location: Moncton, New Brunswick, Canada, The True North Strong and Free!
check your grounds for corrosion? just a thought
Old 04-03-2009, 03:30 PM
GMCtrk's Avatar
Hard to believe, but maybe you got hydrolocked. Try pulling a couple spark plugs out and see what you find.
Old 04-03-2009, 04:30 PM
JHALL7644's Avatar
i pulled my CAI off and there is water present and checked battery and its good
Old 04-03-2009, 04:48 PM
GMCtrk's Avatar
and please change your avatar
Old 04-04-2009, 06:48 AM
JHALL7644's Avatar
ha ha ha ha told my gf not to take it while i was workin
Old 04-04-2009, 07:08 AM
sonoma43's Avatar
check all electrical connections perhaps something came loose enough to get some water in there and screw it up...just a thought
Old 04-04-2009, 08:40 AM
PT's Slowest Truck
budhayes3's Avatar
Not that hard to believe, I've seen it before. As GMCtrk mentioned, try pulling the plugs and see what you'll find, try and crank it over and see if water comes out the spark plug holes. If it still doesn't crank, put a socket on the crank bolt and try to turn the engine over by hand (with spark plugs removed). If it won't turn by hand, it's been hydrolocked and has a bent/broken rod or two.
Old 04-04-2009, 09:57 AM
006rcsb's Avatar
Did the engine die mid puddle or did you make it through? If it died mid puddle i'd say hydro lock but if you made it through and you are trying to start it the day after it might be that you got water in the starter or solenoid.
Old 04-04-2009, 10:49 AM
JHALL7644's Avatar
no was i made through it you could smell like something might have burnt up like the starter,but the starter is clicking but not engaging to turn motor over well i say that might be just water might be on pistons
RustyD
05-23-2016 07:04 PM
SSpeeDEMONSS
10-03-2015 08:21 PM
Infernohoe
48
10-02-2015 10:25 PM
trxmxzx
09-29-2015 07:42 AM
Quick Reply: My 07 Tahoe wont crank
