make my truck beat STI
Old Feb 3, 2015 | 01:01 AM
sbc240sx's Avatar
Registered User
Default make my truck beat STI
so i have a 2005 short bed standard cab. 5.3 it has long tubes cat delete with a flowmaster and a tune. with 4l60e and 2600-2800 stall. yukon limted slip with 3.42 gears.
I NEED TO BEAT A 2006 STI with exhaust and air intake
can i run a texas speed 224r cam with that stall. im also gonna get caltracs,
any other mods i should do?
Old Feb 3, 2015 | 06:52 AM
TIM Z's Avatar
11 sec. Truck Mod
Forced induction
Old Feb 3, 2015 | 09:12 PM
bobfig's Avatar
i think you need somewhere in the 450hp range.
nice cam stall and 150hp shot of nitrous would work.
or just slap a nice turbo on it
Old Feb 3, 2015 | 10:34 PM
Vortec350ss's Avatar
A cam and converter package that's perfect for each other and on the aggressive side may get you there.
To answer your question specifically, no I would not run that cam with that converter. It will be a total dog off the line and after shifts. With that cam you'd want at least a 9.5" 3600 converter.
Boost will be your easiest and quickest answer to serious Performance. You can do it NA, but it will likely require a different exhaust, a different converter, a stronger trans (you'll need that no matter the path), and a cam as you mentioned. Even still an STI is a stout little car.
Old Feb 4, 2015 | 01:46 AM
sbc240sx's Avatar
Registered User
thanks for the input the 4l60e i have is good till 700hp from perfomabuilt so not worried about that. i dont want a bigger stall since this is my daily diver and wanna keep it streetable. i dont want nitrous on my daily. thats for my v8 swaped 240sx.
so now i can go about this 2 ways.
1. keep my swb 2005 silverado cam swap, injectors, fuel pump, then save for supercharger
2. sale the truck and get one of my dream cars since i was a kid. gmc typhoon and do some work to it. i would need to build the running gear ASAP so i can tow my 240 then later do go fast goodies.
what are your guys opinions to this
Old Feb 4, 2015 | 06:31 AM
vettelovralexand's Avatar
Depending on the year of the STI, you are going to have your hands full. If they are willing to launch it hard, that is anywhere from a 13-14 second car. There have been people with NA setups that have had times faster than that, but they are starting to give up driveability/towability for it. Forced induction would give you both.
Old Feb 4, 2015 | 07:57 AM
bobfig's Avatar
probably with that stall max cam i would go is the 212/218 cam on 112lsa safely or if your wanting to push it this voodoo 217/223 or 113lsa. Voodoo Hydraulic Roller Cam - GM LS GEN III/IV 267/273 - Lunati Power
you could upgrade the fuel pump to a walbro 400 in preparation but i wouldn't do injectors till your going boosted.
as for selling and going typhoon i really don't like that idea. they will take just as much if not more work to do what you want.
Old Feb 4, 2015 | 08:24 AM
TIM Z's Avatar
11 sec. Truck Mod
LMAO !!!!!!!!!!
That would be a feat For Rossler in a truck , he's the Only I'd believe that from .
You'll find out sooner than later .
Old Feb 4, 2015 | 08:31 AM
My opinion is that option 1 is a recipe for a truck that is absurdly fast. Here's my advice: change the order. You will be somewhat disappointed with a cam that works well NA and such a small stall. Get the blower first. Find a used 1900 as they are phenomenal for a DD. Then you will have the right stall and have everything built in order to spec the perfect cam.
Old Feb 6, 2015 | 05:28 AM
madmann26's Avatar
Those 3.42's aren't gonna help you any.
You can do it NA but you're going to have to have the right parts and tune.
