LS3 cam in a LM7
Old Jan 8, 2014 | 09:18 PM
JCunningham's Avatar
Default LS3 cam in a LM7
2000 GMC Sierra 5.3l lm7. Im putting a cam in my 12 Camaro so now I will have a cam and springs from my 5000 mile camaro sitting around. was wondering if I could put it in my truck? truck has 90,000 on it so probably should use the camaros springs too. would have New Era dyno tune it. would it be worth it probably cost me a little over $500 with tune($450) and GM parts
Old Jan 8, 2014 | 09:40 PM
Mangled03gmc's Avatar
Baltimore Whore
Almost identical to the ls6 cam(s)
Old Jan 8, 2014 | 09:57 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
The factory LS3 cam is a one-bolt design. Your LM7 needs a 3 bolt.
Old Jan 8, 2014 | 09:59 PM
There is the whole cam sensor thing too...
Old Jan 8, 2014 | 10:07 PM
Baltimore Whore
Nobody needs cam sensors LOL. I thought he was asking for specs. But Roger took it to the proper terms.. Whoo whooop
Old Jan 8, 2014 | 10:25 PM
why would it need a 3 bolt? I thought the 3 bolt was so It could handle the heaver springs. Im putting a 3 bolt in the camaro.
So its a no go
Old Jan 8, 2014 | 11:00 PM
Baltimore Whore
It can be done but the cost to do it, you might as well buy a ls6 cam for your engine. Need to change front cover to 05 up, cam gear, ect
Old Jan 8, 2014 | 11:57 PM
well the cam would use the same gear from the camaro. I have a new chain. 05 cover wouldnt be bad
Old Jan 9, 2014 | 01:38 AM
Baltimore Whore
Better off buying a LS6 cam for 150
Old Jan 9, 2014 | 09:34 AM
what would i be looking at power wise with a ls6 cam
