LS2 cam in 5.3
Old Apr 4, 2017 | 08:35 PM
stpriest1's Avatar
Forgot all about posting the fix. Y'all were right about the LS3 cam not having the reluctor. Changed timing chain set, timing cover and got the adapter harness for the cam sensor relocating to the front cover. Been doing fine since. Thanks for the help !
Steve
Old Apr 7, 2017 | 12:06 AM
01SilveradoJakee's Avatar
If everything is checked out 100% and still doing it, a super simple Cam Crank Correlation Relearn is almost always over looked.
Old Apr 7, 2017 | 08:16 PM
stealthperf's Avatar
I installed an extenstion harness on mine and it was wired wrong. If you look closely at the plug in, you'll see an "A" "B" "C" on each end.... Follow the colors and make sure they line up with the corresponding ABC on the other end.... One of my wires was crossed and went from B to C so it never got the proper signal. I switched it around and it worked perfectly!
chaosz71
Mar 29, 2016 05:21 AM
MOBBN
Mar 13, 2016 08:59 AM
YAMAHAGUY
Mar 12, 2016 07:17 PM
09CamdSilvy
Mar 2, 2016 09:47 AM
