LQ4 oil leak
Old Oct 12, 2013 | 02:25 PM
Bit's Avatar
Bit
^^ true statement
Old Oct 13, 2013 | 02:52 PM
SSpeeDEMONSS's Avatar
Originally Posted by livefast1
If the adapter gasket doesn't fix it its probably the oil pan gasket. There are two pressurized ports integral to the oil pan that feed and return oil from the oil filter. I've seen these leak before.
if i have to pull the engine to fix an oil leak a stock engine won't be going back in. already looking for another 6.0.
Garrett
Old Oct 22, 2013 | 04:05 PM
looks like this is my problem. talked with a friend about what is going to happen with the LQ4 build and it's on hold until my ford gets it's new engine. haven't even looked to see if i can lower the pan enough to change gaskets or RTV it. can i?
Garrett
Old Oct 22, 2013 | 04:09 PM
nickleahy23's Avatar
I dropped the pan in my 4x4 tahoe in under an hour..just had to lower the front diff down. Id imagine its easier in a 2wd
Old Oct 23, 2013 | 08:51 AM
Robert91RS's Avatar
Ya, you should be able to change it in the truck. A dab of rtv at the corners of the pan gasket is common but don't reuse the old gasket and be sure to replace the cooler adapter gasket at the same time.
Old Oct 23, 2013 | 03:23 PM
cooler adapter gasket? the one that i just changed? change it again? looks like i know what i will be doing this weekend.
Garrett
SlvrSierra4.8
Oct 1, 2015 09:39 PM
zraffz
Sep 8, 2015 07:40 PM
custm2500
Sep 8, 2015 05:53 PM
mayko
Sep 7, 2015 12:24 PM
the owl
Sep 4, 2015 04:09 PM
