need some input on brake problem asap
Old Oct 15, 2013 | 11:02 PM
03 silverado's Avatar
Default need some input on brake problem asap
hey guys whats up? well two nights ago i did a lil burnout in my truck for the first time since i got it 3 1/2 months ago. maybe for 15 seconds at the most so nothing to big. well now my brakes suck, pedal goes to the floor at times but then the nxt time ill push it in quarter way and it brakes like it should seems lik if im driving down the highway for 10-15 minutes without touching them they work lik they should but while driving in town using them often they get real soft and the truck bearly stops. this happened right after the burnout so i must've broke something. im thinking either the brake booster went out and is not holding pressure or the master cylinder is shot. figured id ask on here b4 i start throwing money and parts at it if its a simple fix. thanks ahead of time!
Old Oct 16, 2013 | 06:53 PM
Sc00by's Avatar
I would check fluid levels and look for leaks on all corners. Could be a faulty brake booster.
Old Oct 16, 2013 | 07:10 PM
didi that no leaks fluid level is fine i even bled all the lines to make sure it didnt have any air in the system. also its the truck in my sig
Old Oct 16, 2013 | 07:18 PM
whippled 8.1l build's Avatar
still sounds like a leak.. try pumping up the pressure with the truck off and have some one under the truck while doing it
Old Oct 16, 2013 | 07:20 PM
Suburbazine's Avatar
Brake booster makes concrete pedal when bad, not spongy.
Master cylinders are usually an all or nothing part.
Your ABS module may have a jammed valve or you haven't bled your system enough. I'd recommend a full flush with a power flush system if there is a shop with one. You also need to have the ABS module put into service mode (Tech II required) so you can properly bleed all the passages.
There is also a chance you're dragging a caliper, do any of your rotors exhibit signs of bluing or tempering?
Old Oct 16, 2013 | 07:29 PM
ill try that tonight, and im not sure im gonna pull the tires off tonight and check the brake pads all around. i have a new set for the front laying around might throw them on
Old Oct 17, 2013 | 09:22 AM
bobfig's Avatar
rears might need to be adjusted now that you burnt some of the pad off.
Old Oct 17, 2013 | 10:49 AM
06murder's Avatar
Do you have rotors or drums in rear
Old Oct 17, 2013 | 12:45 PM
drums
Old Oct 23, 2013 | 07:52 PM
ended up being the master cylinder, picked one up for $35 at the local junkyard so not to bad
ferrellrooster
Mar 6, 2025 03:22 PM
tgui
Jan 11, 2016 09:11 PM
dry_kill
11
Aug 28, 2015 09:53 PM
Jake99
Aug 8, 2015 07:56 AM
iregret
Jul 27, 2015 10:32 PM
