LQ4 oil leak
truck is nearing 200k and has been problem free the entire time. recently it has started to leak oil. i got under it today to take a look and am not sure what is leaking.
looks like right here.
right here to be exact
from farther back
what is that that looks like it is leaking? is that just a simple gasket?
Garrett
from farther back
Garrett
valve cover looked good. dry. only seems to leave a drop or two where i park but i just changed the oil on the 28th and my low oil light just came on last night.
Garrett
Garrett
It's got full pump pressure when running and you will lose a little bit when you take it off, all the oil will fall from the passages above so it will make a mess if you're not careful.
If the adapter gasket doesn't fix it its probably the oil pan gasket. There are two pressurized ports integral to the oil pan that feed and return oil from the oil filter. I've seen these leak before.
