Lower oil pressure and changed pressure characteristics after dealer resealed oilpan
Old Feb 12, 2020 | 03:53 PM
Jaxon2580's Avatar
Default Lower oil pressure and changed pressure characteristics after dealer resealed oilpan
Hello, I had the a Chevy dealer I had worked at a few years ago re seal the oil pan on my 07 classic Silverado with 266k miles. Before I took it in it always idled at 39-40 psi cold and when driving before warmed up it would run up to the 60psi+ cold then once both oil temp and coolant temp got to operating temps it would idle at 38-39psi hot and go to about 45-55 driving. I'm not sure if they changed the o ring on the pick up tube or something but now when cold on a 40 degree morning no matter what rpm it won't go over 40 while driving but still idles at about 39 cold and once coolant temp and oil temp goes up it goes back to normal pressures to me 45-55 driving which is super odd. I'm running the same oil and oil filter I've been running the past 100k miles I've had the truck, Pennzoil plat. 5w30 and a wix gold filter which they obviously put fresh oil and filter on with the pan re seal. Is there a possibility that a price of silicone or something is blocking the pick up tube and causing different pressures than what I'm used to or am I worrying too much?
Old Feb 12, 2020 | 04:29 PM
FFDP's Avatar
Swap back to your wix filter and see if anything changes.
Old Feb 12, 2020 | 04:47 PM
Jaxon2580's Avatar
The tech used my oil and filter I gave them Pennzoil plat. And a wix filter
Old Feb 13, 2020 | 02:42 PM
stroker87's Avatar
check the oil level? you sure he used your oil? maybe he used a different weight oil the dealer uses?
Kev SS
May 16, 2017 04:07 PM
Fullpower
Dec 16, 2016 08:22 AM
JordanH
Sep 18, 2016 03:05 AM
84_K4
Feb 2, 2012 11:55 PM
YenkoChevelle69
11
Feb 4, 2009 07:38 PM
