Lower ball joint stuck
Old 04-28-2018, 05:14 PM
40series's Avatar
Default Lower ball joint stuck
I can't get lower ball joint free its tappered in the knuckle and I hit it with a PICLKLE FORK for 30 mins and heated it with map gas
no luck
Any ideas?
Old 04-28-2018, 06:49 PM
arthursc2's Avatar
Received 1,436 Likes on 1,063 Posts
Bigger hammer.
I smashed my fork with a 15lb sledge to get me free. Worked
Old 04-28-2018, 07:22 PM
40series's Avatar
Default 4# hammer
I have a 4 pound 🔨
Old 04-28-2018, 11:39 PM
arthursc2's Avatar
Quadruple it and get at it. Bigger hammer, it'll come
Old 04-29-2018, 02:25 PM
Custm2500's Rude Friend
1FastBrick's Avatar
Do it cold. Smack the knuckle where the tie rod goes through with a hammer. Should break the bond.
You can wedge a pickle fork in there and pry up at the same time as well.
Old 04-29-2018, 03:05 PM
SDjeff619's Avatar
Big *** hammer against the lower spindle. I had a hell of a time as well.
Old 04-29-2018, 05:16 PM
madmann26's Avatar
Loosen the balljoint nut. Do not remove the nut.
Take your BFH and smack the **** out of the side of the spindle at the balljoint area. I mean smack it like Ike smacked Tina smack.
If you support the front on a jack stand and do this, it should pop right loose.
Old 04-30-2018, 07:59 AM
ILuvJDM's Avatar
If you already hit it with a pickle fork and heat, then the balljoint is already ruined, so just hit the **** out of the balljoint stud from the bottom and it'll pop right now.
Hitting the spindle is the preferred way if you're going to reuse the balljoint.
Old 04-30-2018, 11:46 AM
BudRacing's Avatar
This. It'll be noisy and you'll be taking many repetitive strikes until it comes loose, and it'll be abrupt. Keep at least 3-4 threads engaged of the ball joint nut and a jack stand or floor jack about 1/2" below the sprung arm. I generally do this with a standard sized hammer--nothing special. You may not want to do this late at night if you've got sleeping fam/neighbors, and you may want to use ear protection if you've got it since it'll leave your ears ringing.
I don't even own a pickle fork--they're fairly useless to me and do more damage than anything useful.
Old 04-30-2018, 11:55 AM
black04's Avatar
If you look on the spindle after taking off the wheel bearing and backing plate there is an X marked between the hole for the hub and the lower balljoint. Just hit that X and it pops right out.
Quick Reply: Lower ball joint stuck
