low coolant resovaire can
Old Aug 7, 2016 | 12:42 PM
40series's Avatar
Default low coolant resovaire can
no leaks but the can was a gallon and a half low, i been hearing air going through the heater core behind the dash board too.
checked the stick and cap no mix there either.
what is going on ?
Old Aug 7, 2016 | 01:31 PM
terravast4's Avatar
maybe you got a set of those leaky castech heads
Old Aug 8, 2016 | 10:36 AM
SnakeOiler's Avatar
if no external leaks, then it must be internal.
Old Aug 13, 2016 | 04:27 PM
Fullpower's Avatar
I had a 5.3L that consumed a quart of coolant about every 12 to 14 days.
After 2 months, it had built up a half gallon of very thick, black TAR like sludge, bottom of oil pan. Very nasty stuff.
Replaced the heads, and camshaft. After 3 oil changes, the bottom of each oil drain still presents some residual sludge, but the OIL on top was always clean, translucent, and looked just fresh from the bottle.
Old Aug 14, 2016 | 11:41 AM
terravast4's Avatar
pull a valve cover and see if you have the castech heads
Old Aug 15, 2016 | 05:43 PM
Fullpower's Avatar
BOTH of my coolant sucking 5.3 LS engines had head(s) NOT sporting a Castech Logo inside.
One engine was from 2002, with 194,000 miles on.
The other was a 2004 model, with only 84,000 miles.
Old Aug 15, 2016 | 09:35 PM
SCChevy's Avatar
I had the same issue and thought that it was the weaping head issue. Turned out it was a bad water pump that was leaking so slowly that I never caught it until I noticed that runout.
B&M Racing
Oct 12, 2017 02:18 PM
Luis3701
Aug 13, 2016 02:40 PM
ironcityboom
Aug 3, 2016 03:10 PM
MikeManer
Jul 27, 2016 08:28 PM
