02 Tahoe, Wires through firewall ?
Old Aug 13, 2016 | 04:31 PM
Fullpower's Avatar
Default 02 Tahoe, Wires through firewall ?
Installing Wideband AFR and Fuel Pressure gauge.
Where's best place to stuff wires through the firewall ?
Also, best place tap switched IGN power to run gauges for a clean install ?
Old Aug 13, 2016 | 04:47 PM
FFDP's Avatar
Next the brake booster is a rubber grommet with wires going into the cabin, I went there on my old sierra. I can only assume they used the same spot on the tahoes.
Just buy a add-a-circuit and run it to a 10amp fuse. I don't like splicing wires if I don't have too. Then pick a circuit that is live when the key is, like an IGN fuse.
Old Aug 13, 2016 | 08:48 PM
Wolftrk99's Avatar
Or an seo fuse... As they are typically meant for accesories anyway... Alot of time when i need a switch power pointi will go to the fuse/junction box under the dash, where the trailer brakes and power seat harness connect.
Old Aug 15, 2016 | 11:29 PM
SnakeOiler's Avatar
Relay box at your feet has plenty of circuits for HOT, ACC, ground, lights, etc. Put a terminal on your wire and plug it in.
TVS/HC
May 3, 2016 10:41 PM
TVS/HC
Apr 27, 2016 01:01 AM
Will
Jul 8, 2002 11:28 PM
Ryan23silverado
Apr 16, 2002 12:09 AM
FASTZ71
Mar 23, 2002 10:16 PM
