line lock on rear brakes?
Old May 1, 2012 | 08:37 PM
WhiteChevy3's Avatar
Default line lock on rear brakes?
I recently bought a BBC 3rd gen camaro, line lock was already installed on rear brake line. Everwhere I read u put it on the front so u can lock the front down while doing a burn out.
I have read on here a few guys putting on the rear to get away from ABS issues, thus keeping the rear from getting pressure while u hold the petal down.
Sounds like it will work both ways... Thoughts??
Old May 1, 2012 | 08:57 PM
Atomic's Avatar
I have a gauge for that
It will work both ways. I would only do it on the front if I had a manual trans, that way you wouldnt have to work 3 pedals at once.
Old May 1, 2012 | 09:40 PM
Mangled03gmc's Avatar
Baltimore Whore
I heard that some were mounting it before the abs sensors or some chit like that, but not 100%. I would also like to know how to do it. I read it one time long ago but since then along with many other things I forget.
Old May 1, 2012 | 10:20 PM
sprayedenali's Avatar
mines on the rears, keeps pressure from getting to the rear calipers when the line lock is on. i just put it in the line right before it goes to the rubber part that goes to the axel
Old May 1, 2012 | 10:40 PM
Atomic's Avatar
Just finished mine last week
Old May 1, 2012 | 10:46 PM
look at those fancy braided lines!
Old May 1, 2012 | 10:52 PM
Atomic's Avatar
left over from when I did the steam vents on the heads
Old May 2, 2012 | 10:33 AM
JoeyGC5's Avatar
Richard, where did you get the an to flare brake line adapter fittings?
Old May 2, 2012 | 11:41 AM
Atomic's Avatar
summit, Female threads - 7/16-24 in. inverted flare - Straight - Brake Fittings - SummitRacing.com
Old May 20, 2012 | 11:12 PM
UnVmy5.3's Avatar
mine is located right after the master cylinder before my abs block and never had a problem on my 01 silverado
