it just cranks,no start.
Old Jul 14, 2011 | 06:21 PM
sierra69's Avatar
Default it just cranks,no start.
i just bought a 2000 gmc yukon 4x4 with a 5.7? off a private party and now when i try to start it in the morning it just cranks for a while. Then after a few minutes it starts.it won,t do it after i have been driving it around awhile,just on the first start in the morning.anybody know whats going on?thx.
Old Jul 14, 2011 | 06:39 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Get a fuel pressure gauge on there. Could be a weak pump.
Old Jul 14, 2011 | 06:41 PM
sierra69's Avatar
will do,and is the fuel preesure port on the fuel rail?
Old Jul 14, 2011 | 07:01 PM
GmJackson53's Avatar
Air fuel and spark are needed for combustion, im sure you know that, but it gives you a "simple" reference point to start with. But this does sound like a fuel issue. I am almost positive a 2000 is a 5.3, not a 5.7 350. Like lowrider said, low fuel pressure caused by a weak pump or clogged fuel filter sound like the simple culprit by what you described. I hope that fixes your issue. As for as the test port, im thinking its on a line coming off of your passenger side fuel rail.
Also, note that when you turn your key, you should hear your fuel pump prime for about 2 seconds, im curious what the pressure is at your rails during that priming...
There are alot of things it could be, i suggest you start by eliminating the simple
Old Jul 14, 2011 | 07:03 PM
Keep us posted on your progress
Old Jul 14, 2011 | 07:20 PM
TIM Z's Avatar
11 sec. Truck Mod
Yes there is a shrader port on the manifold you can hook up a fuel psi gauge.
Should see around 55 -58 i believe while cranking.
I bet your fuel pump is going bad Like Aklowrider said.
Give her a shot of starting fluid in the intake and if it fires well you know your pump or pump relay is bad.
Old Jul 15, 2011 | 06:43 PM
sierra69's Avatar
my gauge says 48 psi @ cranking,and it is a 5.3 sorry guys.
Old Jul 15, 2011 | 06:59 PM
What's the key on-engine off pressure?
48 is too low.
Old Jul 15, 2011 | 09:05 PM
2 EDGE PERFORMANCE's Avatar
Registered User
Possible bad crank sensor. Do you have access to a scan tool? You want to watch for cranking RPM. If it stays at 0 while cranking you have no signal to the PCM. Sometimes a sensor can fail intermittently depending on temperature.
Old Jul 15, 2011 | 10:17 PM
silverado1ss89's Avatar
Fuel pump for sure... Chevy is known for this.. They keep auto parts in business.. Bad fuel pumps..
