I'm getting it! i think! Come in! Quick!
Old May 28, 2011 | 08:47 PM
Huntingman2706217's Avatar
Originally Posted by 2doorfury
there isnt a code on the block?? i know the 6.0's are stamped 6.0L on the side of the block..
where abouts?
Old May 28, 2011 | 09:32 PM
xlcooplx's Avatar
behind the accessory/alt bracket on the DS of the engine. its also cast on the rear of the block behind the flywheel.
Old May 29, 2011 | 02:52 PM
kr1s's Avatar
Originally Posted by Gadgetized
I think the best easiest way to tell would be to remove a spark plug. Turn the engine over by hand until the piston is up. Take a piece of wire and drag it across the top of the piston. The 4.8 has a smooth flat top, and the 5.3 has a dished piston.
so the one on the left is a 5.3? :O
Old May 29, 2011 | 03:26 PM
xlcooplx's Avatar
no, left is 4.8L
Old May 29, 2011 | 07:22 PM
blackcash's Avatar
Also you have a 2000, if the motor is a 2007 the harness is no bueno for you and the motor has a 58(?) tooth reluctor wheel, you need one with a 24x or a converter box. Knock sensors are also located elsewhere (just need an extension harness). Disregard this if it out of a 2007 classic.
Old May 29, 2011 | 08:39 PM
00ChevyScott's Avatar
Wearin' da big hat
The RPO code for 4.8 is LR4
Old May 29, 2011 | 08:58 PM
Coban's Avatar
If its out of a gmt-900 2007 then the 5.3 has flat-top pistons and 243/799 heads.
Old May 30, 2011 | 07:36 AM
Lil brother PI's Avatar
i kow u said u where from the valley PM me might be able to get one with some friends
drummer0415
11
Oct 24, 2015 08:16 PM
Wrecker 426
Oct 7, 2015 12:11 PM
01silvy
Sep 26, 2015 10:20 PM
2004gibbstruck
Sep 7, 2015 06:05 PM
