I'm getting it! i think! Come in! Quick!
Ok so i found the 5.3 with harness for 600$ in a junk yard
Then i found a guy who said he has a motor its either a 4.8 or 5.3 off of a 2007 silverado with harness and transmission for the same price. How can i tell which ones which? I hope i get it today
I would try and put it in tomorrow!
he doesnt know where the truck is that it came from? run the VIN... check the stickers under the hood... door plate... wish i knew more than the common answers... not familiar with whats different on the outside of the motor...
I think i'm just gonna go with him
I think the best easiest way to tell would be to remove a spark plug. Turn the engine over by hand until the piston is up. Take a piece of wire and drag it across the top of the piston. The 4.8 has a smooth flat top, and the 5.3 has a dished piston.
The 4.8, and 5.3 are identical externally. The piston check is the easiest thing that I can think of unless you had the tuner tell you. And then to be honest, even the tuner could be wrong.
