I'm getting it! i think! Come in! Quick!
Old May 28, 2011 | 12:38 PM
kr1s's Avatar
Talking I'm getting it! i think! Come in! Quick!
Ok so i found the 5.3 with harness for 600$ in a junk yard
Then i found a guy who said he has a motor its either a 4.8 or 5.3 off of a 2007 silverado with harness and transmission for the same price. How can i tell which ones which? I hope i get it today I would try and put it in tomorrow!
Old May 28, 2011 | 01:41 PM
Huntingman2706217's Avatar
he doesnt know where the truck is that it came from? run the VIN... check the stickers under the hood... door plate... wish i knew more than the common answers... not familiar with whats different on the outside of the motor...
Old May 28, 2011 | 01:45 PM
kr1s's Avatar
Na its all good the guy at the junkyard has all the specs I think i'm just gonna go with him
Old May 28, 2011 | 03:53 PM
getchya a build thread goin then! lol...
Old May 28, 2011 | 05:12 PM
Gadgetized's Avatar
I think the best easiest way to tell would be to remove a spark plug. Turn the engine over by hand until the piston is up. Take a piece of wire and drag it across the top of the piston. The 4.8 has a smooth flat top, and the 5.3 has a dished piston.
Old May 28, 2011 | 05:34 PM
silver-mod-o's Avatar
Hunt&Fisherator
Or RPO codes in the glove box... LM7 is the 5.3 and LH8 (I think) is the 4.8
Old May 28, 2011 | 06:50 PM
dang... thats the easiest way huh? that sucks... lol...
Old May 28, 2011 | 06:56 PM
2doorfury's Avatar
there isnt a code on the block?? i know the 6.0's are stamped 6.0L on the side of the block..
Old May 28, 2011 | 08:36 PM
Gadgetized's Avatar
The 4.8, and 5.3 are identical externally. The piston check is the easiest thing that I can think of unless you had the tuner tell you. And then to be honest, even the tuner could be wrong.
Old May 28, 2011 | 08:37 PM
xlcooplx's Avatar
smaller v8s are stamped "4.8/5.3" as they're the same block. 8th digit in VIN is T: 5.3 8th digit is V: 4.8
