Ignition source for guages...
Old Dec 27, 2005 | 06:59 AM
Mort's Avatar
Cool
Originally Posted by cbrich
If you can't find an ignition hot wire go to the radio you will find it there for sure. When I did my gauges I found my ignition hot, ground and dimmer in the connection panel located by the brake pedal (GM service manual calls it the mid-bus), this the same panel where a trailer brake controller would connect too.
I can't believe I misspelled illumination.
I tried to use that spot for connections on mine too but they were already taken by some accessory so I used the dimmer for the dash lights but it is not the best option. I have to turn my lights on during the day or my gauges don't work. I can dim my guages but if I dim them too much the voltage drops and they will not work correctly because they are digital and do not have a separate circuit for lighting. The only thing is I can shut them off if I need to be stealthy. One of these days I will change them.
BadAssChevy327 - I think you can buy connectors to fit those pins? Check with your auto parts store.
Old Dec 27, 2005 | 12:58 PM
Deckhand's Avatar
under the steering column is a fat pink wire... that is active when ignition is keyed on, and when you crank.. it dosent lose power (like your radio and the rest of your accessories do).
Old Dec 27, 2005 | 01:05 PM
Tractionless's Avatar
Do you have a pic of this wire? I need to find it to connect the nitrous and purge noids to it too.
Old Dec 27, 2005 | 01:11 PM
SnakeOiler's Avatar
Originally Posted by BadAssChevy327
hows that work , what do you stick there to hold it on
You can use standard Metripak 280 series connectors.
I also used this same source (see post #3): https://www.performancetrucks.net/fo...d.php?t=265663
Old Dec 27, 2005 | 05:04 PM
That is the same spot I used, but I bought the connector from dealer for about $15.
Old Dec 28, 2005 | 05:35 AM
BadAssChevy327's Avatar
awesome , this is good info . thanks
Old Dec 28, 2005 | 02:37 PM
slowprocess's Avatar
Same one I used. I also had to use a white wire in my headlight control panel to control the lights on my autometer gauges. Didn't want them running all the time....only when my headlights were on.
Old Mar 11, 2006 | 08:13 PM
greentahoe's Avatar
Sorry to bring up an old post. Is this the best place to find a 12V switched source? Or is the fuse box on the drivers side a better location? Anyone have pics of where they hooked up? and what kind of connector was needed to fit??
Old Mar 12, 2006 | 07:10 PM
litreddevil's Avatar
Banned
that is what i did for my 3 gaugesand my nos purge
Old Mar 12, 2006 | 09:47 PM
SnakeOiler's Avatar
I have used here and the driver side fuse box for taps. I define 'best place' as anywhere I can tap an electrical feed without splicing a wire.
OHsixLS3
Nov 21, 2015 10:41 AM
dsbodley
Nov 14, 2015 09:46 PM
Velocity1
Sep 22, 2015 01:32 PM
cousblake11
Sep 9, 2015 06:52 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
