I hope this isnt the case
Old Jun 16, 2004 | 05:21 PM
greentahoe's Avatar
Default I hope this isnt the case
As some of you may remember I had my Pioneer head unit die about 13 months after I got it. This was diagnosed by an installer at a local shop that my friend owns. It seemed to be a ground prob to me. It would turn on and off when I hit bumps, but he assured me it was the HU and refferred me to a repair center. They said it needed some connectors and software updates. $200 to repair it. I ordered a new Alpine and went to install it today. It wont turn on at all. If this turns out to be a fuse or wiring problem 2 people are really going to get a serious *** beating tomorrow. Im so sick of ******** taking advantage of people. Im not sure what else it could be, so I will wait to get a definate diagnosis. Do any of you have any ideas?? It is pretty hard for me to get to stuff in there, but from what I can see everything is good. I cant get to the fuse box and I dont know where they grounded it so I cant check that. Im so mad right now
Old Jun 16, 2004 | 05:45 PM
FILE's Avatar
It probably is a wiring/connection problem. Go kick their ***.
Old Jun 16, 2004 | 05:51 PM
XLR8NSS's Avatar
Adkoonerstrator
Connectors and software update?
Sounds like a bad ground to me that may have finally worked it's way loose. Get a voltage tester and see if the ground is any good.
Old Jun 16, 2004 | 06:00 PM
Hit Man X's Avatar
I'm only a phone call away...
Old Jun 16, 2004 | 06:06 PM
moregrip's Avatar
what a rush!
Good luck bro. believe me, I know how feels to get fu%^ed!
Old Jun 16, 2004 | 06:42 PM
try taking a wire to a point where you know is a good ground and connect it to the deck and see if that works. i had something similar happen in my 91 gmc rcsb. i ran a ground wire straight to the frame and never again had probs!
just tryin to help!
Old Jun 16, 2004 | 07:43 PM
greentahoe's Avatar
Thanks for the support guys. I tried getting in there to see if I could just start from scratch, but it is a total and complete mess. There are wires left in butt connectors and one end is simply cut and they are stuffed back there all over the place. I dont have a voltage tester, so Im a little limited. I guess Im going to talk to the owner tomorrow and have him fix it then and now. While that is in the works I will have a talk with the other installer. If we see eye to eye than it will be left at that. Otherwise I will grant him a very short work day. Im just fed up with this stuff. I will definately keep all of you posted.
Old Jun 16, 2004 | 10:26 PM
F8L Z71's Avatar
That's all bad man I am not skilled enough to even be let into our install bay and even I don't do that. LOL
If you don't have access to a multimeter you can buy a cheapo testlight form RadioShack or even Walmart and test for ignition voltage (when the key is in the on position) and constant 12v NP. Like stated above you can easily run your own ground.
If you wanna chekc a deck quickly for power simply twist the Constant 12v wire (Yellow) and the Ignition 12v wire (Red) together and touch em to your truck battery +, and touch the ground to the batter - and the deck should power up. Ghetto but it works. Just make sure you still have the fuse on the 12v constant wire
Old Jun 17, 2004 | 10:34 AM
greentahoe's Avatar
I just got back from the stereo shop. I went in and asked to speak with Chris (owner) and told him that my new HU wasnt working. I told him it did the same thing that my old one did and that his installer told me the old HU was broken. He said I'll have him meet you at your truck. The guy came out (same guy) and was very nice. I told him what was happening and he said he would fix it right now. 15 minutes later he was done. I asked him if it was a ground prob and he said no, I didnt have the right alpine connector. I asked him to show me which he immediately did. I told him that the repair place said it would be $200 to fix my old HU and he said if I wanted to go pick it up he would show what was wrong with it. He then said if I wanted he would fix it and pay me $200 for it since he could resell it for at least $400. Im very happy with the outcome and I tipped him $20 when I left.
Anyways thanks for listening guys.
Old Jun 17, 2004 | 12:52 PM
leochevy2001's Avatar
Glad everything worked out for you. It would have been pretty shitty if they were screwing you.
whitelazer
Sep 22, 2015 09:38 PM
bluestang50
Sep 21, 2015 08:36 AM
69z-28
Sep 21, 2015 07:31 AM
Silver8ado
Sep 14, 2015 06:35 PM
shaun 95 2door
Sep 13, 2015 01:47 PM
