i am prety pumped up, keeping the shiping companys busy.
Old Oct 28, 2003 | 05:36 PM
  #21
parish8's Avatar
single digit dreamer
i have the front and rear drivshaft coming. i have no idea if it will fit or what would be required. what i do know is it is a similar design, just looking at it there is a chance that it could bolt right in. the 2500 diff is flanged just like the 1500 one. if the unit is the same width as the 1500 then i think i can make it work. mounting it and conecting the flanges shouldnt be all that hard.
hoping it just bolts right in though
Old Oct 28, 2003 | 07:49 PM
  #22
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
Originally Posted by 1BADHD
The front diff is the same for the 6.0, 8.1 and D-max.
"Models equipped with the Vortec 8100 or Duramax 6600 have a new aluminum "Powerdense" case with extra ribbing that provides significantly more strength for the front axle’s external housing structure."
Old Oct 28, 2003 | 08:23 PM
  #23
1BADHD's Avatar
I see that was put out in 2001. I have had my front diff out and a 2002 8.1 front diff out and they look the same. I wonder if they are all the same after 2001? My truck is a 2001, but was one of the last made before the 2002 model year?
Old Oct 28, 2003 | 09:41 PM
  #24
1TRUESS's Avatar
Talking
Maybe some how my address will pop up on those packages!
Old Oct 29, 2003 | 05:59 PM
  #25
we looked into upgrading the front diff on the older body style truck 88-98 and it couldnt be done. The mounting points were different. IM sure it could be done with some custom work, but it would not have been a simple bolt on job. Also the axles would not be interchangeable. In order to do it, youd probably have to upgrade the whole front suspension. And probably end up with an 8 lug front end
Old Oct 29, 2003 | 11:17 PM
  #26
Hit Man X's Avatar
An 8 lug front end would be cool with a 10.5" rear axle too! Then you'd have a 2500HD disguised as a lowly 4.8 powered (according to the vin) 1500.
Old Oct 29, 2003 | 11:27 PM
  #27
Black Blown 02's Avatar
What are your plans for the rear end?
Did your last truck just have the stock 10 bolt?
Old Oct 30, 2003 | 02:52 PM
  #28
Yeah it definately would be different. A 10.5" axle would be overkill i think though. Those things are really heavy. A good axle to put under there without having to do much work to it would be a 9.5" 14 bolt. Its a semi floater with a 9.5" ring gear and they can be found relatively easily in 8 lug
Old Oct 30, 2003 | 03:59 PM
  #29
parish8's Avatar
last truck had the stock 10bolt, it held up fine and didn't have any of the extra stuff you can buy for it like the oversized studs and the special cover. i plan on running that stock 10 bolt till it gives me trouble. got to remember i am running stock or near stock tires so there is only so much power it will have to take before it peals out.
the front will be taking a beating though, i am hoping to just swap the center part and use the 1/2 ton cv joints/axles whatever they are called. i am waiting for the motor to show before i pay for the front end so it will be a few weeks before i even get the thing.
Old Oct 31, 2003 | 07:22 PM
  #30
goshawk23's Avatar
Truck addict
man, all i can say is, it must be nice to do projects like this. i hope to see the days like this.
ss4chad
Aug 15, 2015 02:25 AM
JordanH
Aug 8, 2015 07:59 PM
05GMC4.8
Aug 7, 2015 09:55 PM
MileHighSierra
Jul 22, 2015 11:19 PM
