i am prety pumped up, keeping the shiping companys busy.
Old Oct 28, 2003 | 08:04 AM
rgvsierra's Avatar
Originally Posted by parish8
the gauge only works with the fjo wideband set up, it was prety expensive too.
rg, you mean with a big shot right? i think it is at least posiable, dont know if i can do it but i will try. last truck got a best of 11.92 with 8psi and a 75shot, i got up to 9psi and a 100shot on the street but no track time, now drop 500lbs, add a front locker. hmm, could happen.
yea, a big shot, but just a regular 6.0 engine.. guess i should of added that.
Old Oct 28, 2003 | 09:28 AM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
Which front diff are you going with? The 8.1/Dmax front diff is stronger than the 6.0 front diff.
Gonna put a locker up front?
Old Oct 28, 2003 | 09:32 AM
1BADHD's Avatar
The front diff is the same for the 6.0, 8.1 and D-max. The rear diffs are different.
Old Oct 28, 2003 | 10:58 AM
Hit Man X's Avatar
Nice stuff. I am very intrigued on how the larger front diff will (if) bolt in to the 1500 frame
Old Oct 28, 2003 | 11:02 AM
1BADHD's Avatar
The 1500 is a 8.25" ring and the HD model is a 9.25" ring gear. The case is bigger. But I beleive the mounting points are the same.
Old Oct 28, 2003 | 11:12 AM
JSmith's Avatar
Sweet! I can't wait to see what this thing runs when you're done!
Old Oct 28, 2003 | 03:36 PM
Hit Man X's Avatar
Hrm interesting info.
Old Oct 28, 2003 | 04:05 PM
parish8's Avatar
single digit dreamer
i HOPE to run the 1500 autotrack transfer case and 1500 front end for awhile but dont know if that will work out or not. if i have to change the transfer case and rework the driveshafts i will probably try and get the front diferential in right away, have to leave out the front drive shaft till i get some 4.10's in the rear if i do that. hell yea, i want a locker in the front and a good posi in the rear, i am all ready turning over 3/4 tires with just a 100shot, might just end up smoking the tires once i get moe power.
Old Oct 28, 2003 | 04:17 PM
silent1's Avatar
Parish, Sent you a PM.
Old Oct 28, 2003 | 05:26 PM
Hit Man X's Avatar
I wonder if the Constant Velocity joints are the same on the 1/2 ton as the 3/4 ton..spline count and length wise?
Did you happen to get the front drive shaft also for the HD front diff and HD t-case?
Trying to come up with all contingent (sp?) possibilities so you aren't suprised by anything.
