How hard is it to install Escalade gauge face?
Old May 26, 2008 | 02:16 PM
10 Second Club
Default How hard is it to install Escalade gauge face?
I have an 04 Yukon and I am going to order these gauges... how hard is the install. And what kind of tool do I need to remove the needles and calibrate them right etc.. Here is the kit I am ordering.
http://www.jpcustoms.com/store/custo...cat=967&page=1
Old May 26, 2008 | 04:43 PM
chevyguy7802's Avatar
Shouldnt be too hard.....the place your buying the gauge face from should carry the tool.....or maybe you should call and ask to see if it come with it.....
Old May 26, 2008 | 05:13 PM
02BlueStepside's Avatar
From what I understand, the hardest part will be putting the needles back on in the same spot. Take a detailed pic of each needle before you pull it off and refer back to it when putting it back on.
Old May 26, 2008 | 05:16 PM
Just saw this, great price and no fooling around with the needles
HERE
You will have a functional tranny temp gauge with this too. Only thing is you will have to have the mileage programmed
Old May 27, 2008 | 01:22 AM
spitfire2332's Avatar
wow, 240$ is extremely high for gauge face, needles and bezel. I would honestly contact usspeedo (I think they are a supplier to JPcustoms) and just deal with them direct. They can also program it for you
Old May 27, 2008 | 03:20 AM
jetmann's Avatar
Check E-Bay, I bought A brand new cluster for 240. 0 miles 0 hours and it is A heck of a lot easier to pull yours out and install A brand new one than mess around with changing the face. Oh and the new cluster came with A trans temp. Plug and play in 5 minutes and you have your old one if needed.
Old May 27, 2008 | 07:13 AM
moog5050's Avatar
Changing the face on the same type of gauge is not hard ... it took me less than 1/2 hour and that was with resetting one of the needles twice. Basically you remove the gauge (4 screws) remove the back and pull the needles (they simply push on and off buit are tight) and then reassemble. Be sure to note where all the needles sit with the ignition (not motor) on because that is where you want to replace them. I still have an ss overlay if you are interested. I went with us speedo and found one on ebay for $75.
Old May 27, 2008 | 09:44 AM
10 Second Club
Hey what do yall think about this offer?
http://cgi.ebay.com/ebaymotors/Parts...m330239586044&
Its either that or buying a brand new cluster for twice that price. .
Old May 27, 2008 | 07:04 PM
454navyss's Avatar
i bought an escalade cluster off ebay for $175 shipped.... just saying
Old May 27, 2008 | 09:34 PM
jpcustoms is no better deal than going to a dealer. In your link from them, your buying the whole bezel, not an overlay FYI.
Installing a whole cluster is easy, remove dash overlay, remove 4 7MM nuts at each corner, disconnect harness, reverse.
For an overlay drive it around the block to get everything where it would normally be, mark the needle spots, get a fork, pop the needles off put gauge face on, reverse.
