High Jacked!!!!
Old Apr 11, 2012 | 03:55 PM
00loudchevy's Avatar
Default High Jacked!!!!
Ok guys help me out. I high jacked my son account on here. We are having a highly contested debate about the way to build his engine. First it started out as a stock 5.3 liter iron block. We have a ds1 Procharger that will be putting out 15lb of boost. It will be recieving new forged rods, pistons, and crank. We have a set of 317 truck heads. Freshed with new springs, valves & roller rockers. Our cam wil be custom grind to match plus a torque convertor to match. What way do you think would be better....boring out the 5.3 to a 5.7 or simply replacing it with a 5.7 or 6.0. Should we stroke the 5.3 also or leave the stock stroke? Plus do you think we can still push a small shot of nitrous through it being ProCharged?
Thanks
Concerned Dad
Old Apr 11, 2012 | 04:24 PM
oakley6575's Avatar
Personally I would just find a used 6.0L and throw everything on that. Simple swap and I think it would be worth it over boring the 5.3L. I have heard good things about the LS9 cam so far.
More info one the truck and set up would be good. Is this a daily driven truck? Year/Make/Model?
You can run a small shot of nitrous through it if it's going to be built and be able to handle all that power. A lot of guys use nitrous as a cooling agent for high boost applications. Instead of going that route, I would put methanol/water injection on it. Sounds like nothing but positive effects with water/meth. GL
Old Apr 11, 2012 | 04:48 PM
6.0 w/ a ls9 cam would run great
Old Apr 11, 2012 | 04:53 PM
it's a daily driver. 2000 Chevy Silverado Ext Cab.
Might be able to get a cheap LS6 block locally too.
Old Apr 11, 2012 | 04:57 PM
oakley6575's Avatar
Yea since it's a daily driver, I would run the ls9 cam. But at the same time, I don't know how the 317 heads would like that cam. Procharger with meth and you should be able to handle 15psi everyday.
find u an lq4 6 liter, put some rod bolts in it, ls9 cam and call it good. good DD motor, and make great power with a procharger. This is the easiest and best bang for the buck in my opinion. u could always stick some l92s on it with an intake to help that cam breath also.
Old Apr 11, 2012 | 08:08 PM
batboy's Avatar
11 Second Club
FI engines seem to work better with shorter strokes. If you already have a 5.3 motor, by all means use it. Boring it out to 5.7 size would be a bonus. The rest of the mods look reasonable. A forged rotating assembly with ARP rod bolts should handle a boost and a small shot of giggle gas. Small is subjective, what size are you thinking?
Old Apr 11, 2012 | 08:16 PM
TIM Z's Avatar
11 sec. Truck Mod
Yep ^^^^!
Or just run the stock 5.3 and boost it with a good cam and headers exhaust .
Like myself there are lots of stock long block boosted guys here running 10's/11's all day long with stock LS engines, They dont Need built.
madmann26
Apr 29, 2020 09:17 AM
smok'nZ
Oct 6, 2015 01:14 PM
carid
Oct 1, 2015 09:22 AM
Slammed silverado
Sep 28, 2015 06:14 PM
sTNT971
Sep 26, 2015 06:27 AM
