heater is a little weak, why?
Old Dec 15, 2008 | 10:38 PM
OLDPOS's Avatar
Default heater is a little weak, why?
Ok its cold today and really the first time this season I needed the heater, turned it on... truck warmed up... blowing strong... but not hot at all it was luke warm at best. Could the heater core be pluged up? What do you guys think?
Old Dec 16, 2008 | 08:35 AM
Check the thermostat first. Make sure it's heating up to the proper temp. second, you may have a blend door or a hot air door staying open or partially open. This is usually due to a faulty actuator, or could simply just need a re-park done.
Old Dec 16, 2008 | 10:36 AM
hirdlej's Avatar
Saw this on a friends car recently, his water was so low in his radiator that it couldn't flow through the heater core. Hear any gurgling from the dash?
Old Dec 16, 2008 | 02:42 PM
chevrolet all the way's Avatar
mine was doin that except worse. was up to temp, had plenty of coolant, thermostat worked... flushed the heater core with a water hose and it works fine now!
Old Dec 17, 2008 | 07:19 PM
OLDPOS's Avatar
The engine is up to temp, coolant is full (but old), so Im ether pluged up in the heater core or need the door thingy fixed. When it warms up i will flush the system and see if that helps. Thanks guys.
Old Dec 17, 2008 | 07:23 PM
buzzkillwill's Avatar
Could be that there's air in the line, and of course it's probably all in the heater core.
A flush and fill is probably in order. BTW, where's Liberty, MO??
Old Dec 22, 2008 | 10:48 AM
OLDPOS's Avatar
Its on the north side of K.C. I have bought a new thermostat and temp sensor (truck is old these parts probly need replacing anyway) the stuff to flush the system, and new coolent, I will have to wait for a warmer day though. but we will see how it goes.
Old Dec 22, 2008 | 11:53 AM
trxmxzx's Avatar
13 Second Truck Club
mine did this last year... sometime it would be warm.... i checked the hoses when up to temp plus driving around and the upper hose was warm but the bottom was cold... im not sure what it was but when i did my motor swap i put a new water pump on and it works great now.. maybe that was my issue (water pump)... just somethings else to look at....
Old Dec 28, 2008 | 02:45 PM
OLDPOS's Avatar
ok I installed new temp sensor(that fixed the gauge) new thermostat and flushed the system and new coolant is now in. The heater works great for about 30 sec. when the truck is warm then slowly drops in temp until its just a vent. I squezed the upper rad hose a few times and heater will work great for a little bit, So do I just have air in my heater core and if so how do I get it out.
creekrat
Sep 10, 2015 12:59 AM
BlackGMC
Sep 9, 2015 01:43 PM
the owl
Sep 4, 2015 04:09 PM
Tigger Welder
Sep 2, 2015 08:17 AM
