heated seat help!
No need to take the seat out. Just leave the seat bottom out. But before you disconnect the seat module under the seat bottom, lay the seat back all the way back. Unhook the bottom of the seat cover. Then run your hand up he cover to unhook the Velcro strips that attach to the foam. Once you have it unhooked you can feel and possibly see the burnt spot. I usually find them at the top. Just be careful when tearing it off the foam not to take too much off. The new element will be a peel and stick. just start one of the corners on each side, and then peel it off when it is in place.
