heated seat help!
12 Second Club
heated seat help!
hey guys got a problem and it seems once they start the little crap dont stop lol.
well i need some help with my front drivers side heated seat.
it was working fine then a few days ago i would turn it on and it would turn it self off after a few mins then i would turn it back on and it would stay on now as soon as i push the button it turns right back off.
any ideas?????????????
truck is a 04 escalade ext.
thanks!
thanks!
12 Second Club
ok well i noticed some other things that might diagnose what it is.
the passenger side works perfect but when i turn the drivers side on and it shuts off it also will turn off the passenger side also but once i turn the passenger back on it stays on and works as it should. so i dont think it could be in the drivers seat maybe a relay?
let me know your ideas and thanks again.
Was the driver's seat VERY hot the last few times it worked?
It's probably a bad seat element like chevymec mentioned.
My GMC did that and I replaced both the drivers and passenger seat and back elements. After i took the leather covers off the elements were melted to the foam in the seat. they all came apart with some patience. but i installed the new elements and they all work now. I cant believe GM has recalled this - i would think if you went to warm your truck up in the winter and turn the seat on or had the seat on for extended period of time that it could cause it to catch fire...
If i could get gmpartsdirect.com to work right i would get the parts number for you. But search and get them there they are way cheaper than the stealership
the passenger side works perfect but when i turn the drivers side on and it shuts off it also will turn off the passenger side also but once i turn the passenger back on it stays on and works as it should. so i don't think it could be in the drivers seat maybe a relay?
The drivers side seat will over ride the passenger seat and cut it off when the element is bad.
Dorman p/n for seat bottom is 641-105
seat back is 641-106 .Go to any parts store and they can use those number or cross it to another manufacturer.
12 Second Club
ok i got the frivers seat bottom off a few min ago and it dont seem to be burnt or melted so i guess it has to be the seat back element.
can anyone tell me how to get the seat back apart to swap out the element?
i know i need to take the seat out of the truck to do it.
thanks
thanks
