GMT800 Third Brake Light Leak
Old Dec 29, 2010 | 11:13 PM
Bigredmariner's Avatar
Default GMT800 Third Brake Light Leak
Moved the truck around today and water ran out of the headliner.
The gasket seal around the third brake light is leaking, I pulled it and siliconed the thing. I have been searching but haven't found a part number for the gasket that seals the light. All I find says that you have to get a new light assembly which comes with a gasket on it.
Any body have the same experience with this or a better remedy? I know I could get some weatherstripping stuff and make my own or just stick with silicone. But I'm a little **** about using factory gaskets and seals as opposed to rigging things.
Old Dec 29, 2010 | 11:16 PM
viciousknid's Avatar
Where's the Beef?
I'd just rtv it. If it works on an intake it'll work on a brake light.
Old Dec 29, 2010 | 11:37 PM
Yeah I used some good black rtv this evening on it, just wondered if a gasket was even available.
Old Dec 30, 2010 | 03:01 PM
hirdlej's Avatar
I had this happen, just went to the junkyard and picked up another one
Old Dec 30, 2010 | 03:42 PM
I may just get a new light assembly sometime this spring then. The sun has worked this one over pretty good anyway since the truck has never been garaged.
Old Jan 2, 2011 | 01:36 PM
DGGMimpala's Avatar
I had the same problem but mine was running down the panels out if sight. I tried compressed air and soapy water trying to find the leak. I finally pulled off all the trim to find the leak. It was amazing I got the amount of water though that light.
No, gasket is not available separately from gm or ac/delco, I hated to do it but ended up filling it with silicon.
Old Jan 2, 2011 | 01:49 PM
Thanks for the input, looks like I'll get a new assembly then sometime soon. The silicone will work for now until I get a new one.
Old Jan 3, 2011 | 07:30 PM
Haha! I have gone through 3 of these. Do you have subwoofers? That is what caused my failures. I RVT'ed the last one and it still leaked (many months later). I think I am going to have it shaved. That should fix it!
Old Jan 3, 2011 | 09:18 PM
No subs for me, I'm already hard of hearing as it is.
Corvette454l88
Sep 1, 2016 01:24 AM
08lambochevy
Aug 14, 2015 07:50 PM
97aztecgt
Aug 13, 2015 02:11 PM
atxlt
Jul 20, 2015 11:06 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
