GMT800 Third Brake Light Leak
Moved the truck around today and water ran out of the headliner.
The gasket seal around the third brake light is leaking, I pulled it and siliconed the thing. I have been searching but haven't found a part number for the gasket that seals the light. All I find says that you have to get a new light assembly which comes with a gasket on it.
Any body have the same experience with this or a better remedy? I know I could get some weatherstripping stuff and make my own or just stick with silicone. But I'm a little **** about using factory gaskets and seals as opposed to rigging things.
I had the same problem but mine was running down the panels out if sight. I tried compressed air and soapy water trying to find the leak. I finally pulled off all the trim to find the leak. It was amazing I got the amount of water though that light.
No, gasket is not available separately from gm or ac/delco, I hated to do it but ended up filling it with silicon.
Haha! I have gone through 3 of these. Do you have subwoofers? That is what caused my failures. I RVT'ed the last one and it still leaked (many months later). I think I am going to have it shaved. That should fix it!
Corvette454l88
Sep 1, 2016 01:24 AM
08lambochevy
Aug 14, 2015 07:50 PM
97aztecgt
Aug 13, 2015 02:11 PM
atxlt
Jul 20, 2015 11:06 PM
Offroadunleashed
Jul 20, 2015 02:25 PM
