GMT 800 (NBS) Drop Thread Specs and Pics Required
Old Nov 23, 2014 | 08:46 AM
  #41
turbodriven04's Avatar
Registered User
03 Z71 265/65/18, 2500 torsion keys, rear blocks removed and 2" drop shackle, bump stops cut
Old Dec 14, 2014 | 08:39 PM
  #42
1987cut's Avatar
2004 silverado reg cab
4/6 mcgaughy drop
20" silverado SS wheels
275/45-20 Nexan tires
Attached Thumbnails GMT 800 (NBS) Drop Thread Specs and Pics Required-image.jpg
Old Dec 15, 2014 | 05:24 PM
  #43
1987cut's Avatar
Why drop the 2" on the leaf hanger? Just curious if it was to level it out with the front after installing your drop kit?:
Old Dec 30, 2014 | 09:14 AM
  #44
texasglock23's Avatar
Truck
2004 5.5ish/8" drop
Tire Size
275/45/20 (rubs)
Front Drop
MCG 16" spindles (with mod)
Ridetech coilovers
Rear Drop
belletech Shackles and flip kit
Shocks
Belltech Street Performance drop shocks (rear)
Misc. Parts
Belltech bumpstops 1.26'' tall (front)
MCG c-notch (bolted and welded)
MCG helper bags
4* pinion shim (I believe, whatever came with my BT kit, can't remember)
day I bought it
now
Old Dec 31, 2014 | 07:18 PM
  #45
travieso's Avatar
Originally Posted by A4edwin
Tony's kit 3-5/6
Djm lower control arms
Belltech sp shocks all around
6 inch lowering spring with 1 inch spacer for 5 inch drop in rear
Spohn panhard bar
Djm rear hardware kit trailing arm extenders and shorter end links.
24x10 dub homies on 305/35 nankang sp7's
Airlift helper bags
nice truck man how's the ride?
Old Dec 12, 2016 | 05:34 PM
  #46
R3d's Avatar
R3d
Registered User
hey everyone,i went thru this thread and saw all of your trucks and they all look awesome! i wanted to do a 3/5 drop on my truck,i have a 00 silverado ext 5.3 2wd. iwas wondering if you guys could help me and point me in the right direction as to a kit or some kind of combination i should do. i dont plan on flipping the rear springs. preferably a kit that comes with shocks already would be nice.
Thanks,Michael
Old Dec 12, 2016 | 05:52 PM
  #47
FFDP's Avatar
You won't get a 5in rear drop without doing a flip kit.
Shackles and hangers will only net you a 4in drop, 5in requires the flip kit.
Old Dec 20, 2016 | 07:42 AM
  #48
dhorner77's Avatar
And as someone with the same truck as you, you are going to want to c notch it as well. Even with a 2/4 drop I hit the bumpstops on the rear. There just isn't enough room for suspension travel. I used mcgaughys kit on mine which worked ok although the directions were ****. I really despise the reduced turning radius as well. I have thought a lot about trying different spindles because of this.
Old Dec 20, 2016 | 08:36 AM
  #49
S14serge's Avatar
Originally Posted by JPSIERRA
Truck
2002 GMC 4.8
Tire Size
255/45/20
Front Drop
McG 2" spindles (16")
McG 2" springs
Rear Drop
McG flip kit
Shocks
McG drop shocks
Wheels
CENTERLINE TOMCATS
Did you have to do a C notch for the rear?
Old Dec 30, 2016 | 05:56 PM
  #50
Btravis90's Avatar
bolted on some hangers yesterday sitting at a 2/4 now. need to take the front down another inch... debating on waiting for a notch so i can remove my overload and do spindles at the same time putting me at a 4/5. pics are shitty and my driveway is super uneven.
