GMT 800 (NBS) Drop Thread Specs and Pics Required
Old Mar 15, 2014 | 08:45 PM
  #21
BTK's Avatar
BTK
I apologize for the large pics.
Truck
2006 Chevy Silverado CCSB 2wd (Z85) with 4/6 drop
Tire Size
275/45/r20
Front Drop
-McGaughy 17"+ Spindles
-McGaughy 2" Lowering Springs
Rear Drop
-McGaughy 6" Rear Flip Kit/ C Notch
-McGaughy Rear Shock Extenders
Shocks
Front- McGaughy 1451
Rear- Factory GM shocks
Misc. Parts/Notes
-I would recommend not installing the rear bumpstops, my truck rides waaaayyy better then factory without them, bottoms out every so often but is not harsh.
-You need the carrier bearing shim if you have a 2 piece, I had a one piece so no issues.
-This tire size is perfect, doesn't rub at all.
-You do lose some turning radius with these spindles, but its still drivable.
Before (with 2'' shackles, 275/55/r20)
After (Still waiting on front to settle, currently at around 3" drop. Just installed this week)
Old Mar 17, 2014 | 05:01 AM
  #22
robm-951's Avatar
2000 ECSB w/ a 3"/4.5" drop (approx)
Front: Suspension source 2" drop spindles and 1" drop springs
Rear: Beltech flip kit with an 2" add a leaf
Tires 275/45/20's
Attached Thumbnails GMT 800 (NBS) Drop Thread Specs and Pics Required-my-truck.jpg
Old Apr 11, 2014 | 04:06 PM
  #23
calboi's Avatar
front-djm 4" drop arms with a 1/4 cut coil
rear-djm flip kit and notch
tires are stock 255/70/16
Attached Thumbnails GMT 800 (NBS) Drop Thread Specs and Pics Required-621-6.jpg   GMT 800 (NBS) Drop Thread Specs and Pics Required-626-.jpeg
Old Apr 11, 2014 | 05:01 PM
  #24
Txblue's Avatar
How did you figure out what coil over(height and spring rate and so on) I have djm 4 inch drop upper and lower control arms with stock spring now.
Old Apr 11, 2014 | 07:37 PM
  #25
calboi's Avatar
I just cut 1/4 of a coil off the stock spring
Old Apr 17, 2014 | 03:06 PM
  #26
A4edwin's Avatar
Tony's kit 3-5/6
Djm lower control arms
Belltech sp shocks all around
6 inch lowering spring with 1 inch spacer for 5 inch drop in rear
Spohn panhard bar
Djm rear hardware kit trailing arm extenders and shorter end links.
24x10 dub homies on 305/35 nankang sp7's
Airlift helper bags
Old May 1, 2014 | 12:59 AM
  #27
JPSIERRA's Avatar
Registered User
Truck
2002 GMC 4.8
Tire Size
255/45/20
Front Drop
McG 2" spindles (16")
McG 2" springs
Rear Drop
McG flip kit
Shocks
McG drop shocks
Wheels
CENTERLINE TOMCATS
Old Nov 15, 2014 | 11:17 PM
  #28
bigfatls6's Avatar
Whats the lowest you can go in the rear with out doing a c notch?
Old Nov 15, 2014 | 11:19 PM
  #29
FFDP's Avatar
4in roughly.
I have a 2/4 drop and still have enough space for the bump stops and won't bottom out. If I hauled alot of stuff or towed a trailer alot it would likely bottom out alot, but then I'd just install some helper bags.
Old Nov 15, 2014 | 11:22 PM
  #30
bigfatls6's Avatar
How much does the c notch weaken the rear frame rails? I have a 2005 sierra rcsb and looking to lower it but not sure If I will leave it lowered forever
