Gm Part #anyone?
Old Jan 20, 2007 | 09:53 AM
  #361
CHEVRACER83's Avatar
Originally Posted by valsperformance
The ones used with the spacer and 6.0 plate? Doing a 4l80 conversion and that is all that I need to install...
THE STOCK 6.0 FLEXPLATE BOLTS FOR A 2005 6.0 ARE # 12553332
IF DIFFERENT GIVE ME A YEAR TO LOOK AT
Old Jan 20, 2007 | 10:00 AM
  #362
Originally Posted by truckmann
I would like to know the part number for the flasher/blinker relay module for the trailor light system on a 2003 Silverado.
Maybe im nuts... but i know the ralays there... but where is this module located?
the relay is number 12177236
Old Jan 20, 2007 | 10:08 AM
  #363
truckmann's Avatar
The module is located in the back side of the interior drivers side fuse block. I am not sure mine is bad but I am losing power to the drivers side Trailor brake light and if I tap on the fuse block infront of that module it comes back on. Until I use the blinker at least. It appears that all of power for at least the trailor lights runs through that module so I am thinking mine might be bad.
Old Jan 20, 2007 | 10:12 AM
  #364
when the trailer light goes out did you notice if the rest of taht side on your truck went out too?
Old Jan 20, 2007 | 10:27 AM
  #365
truckmann's Avatar
The brake lights on the truck work fine, but I am not getting power to the wire for the Drivers sider trailor brakes. The blinker part works fine so I don't believe there is a connection problem or wiring problem. I tracked it down to the fuse panel and I am not getting power to the fuse for the drivers side brake lights at all times. I pulled the flasher module out and inspected it, I didn't see any noticable problem with it. So I put it back in and then the brake light started working again. Until I tested the blinkers and then no power to the drivers side brake light again. Then when I tapped on the fuse block the power came back on.
Old Jan 20, 2007 | 10:32 AM
  #366
Ok Truckmann.... Can You Pm Me Your Vin, And Ill Pull Up Your Exact Fuse Panel And Take A Look? Ill Bet That Module Is Bad.... Its Probably Worn Out.
Old Jan 20, 2007 | 10:34 AM
  #367
truckmann's Avatar
PM sent
Old Jan 20, 2007 | 10:47 AM
  #368
Ok The Module/ Flasher On The Back Of Your Fuse Panel Is Pn 15764135.... That Should Fix Your Problem.
Old Jan 20, 2007 | 10:49 AM
  #369
truckmann's Avatar
Thanks!
FYI if anyone else happens to need one of these. When I looked it up on GM part direct they say the part number has been replaced with this one 10383321
Old Jan 20, 2007 | 10:50 AM
  #370
NO PROBLEM... IF YOU HAVE ANY OTHER QUESTIONS PLEASE FEEL FREE TO ASK... i AM WORKIN TODAY... AND i HAVE MY TRUCK ON THE LIFT CAUSE I DONT FEEL LIKE TOUCHING TAHT DAMN LS7
