Gm Part #anyone?
#361
Originally Posted by valsperformance
The ones used with the spacer and 6.0 plate? Doing a 4l80 conversion and that is all that I need to install...
THE STOCK 6.0 FLEXPLATE BOLTS FOR A 2005 6.0 ARE # 12553332
IF DIFFERENT GIVE ME A YEAR TO LOOK AT
#362
Originally Posted by truckmann
I would like to know the part number for the flasher/blinker relay module for the trailor light system on a 2003 Silverado.
the relay is number 12177236
#363
The module is located in the back side of the interior drivers side fuse block. I am not sure mine is bad but I am losing power to the drivers side Trailor brake light and if I tap on the fuse block infront of that module it comes back on. Until I use the blinker at least. It appears that all of power for at least the trailor lights runs through that module so I am thinking mine might be bad.
#365
The brake lights on the truck work fine, but I am not getting power to the wire for the Drivers sider trailor brakes. The blinker part works fine so I don't believe there is a connection problem or wiring problem. I tracked it down to the fuse panel and I am not getting power to the fuse for the drivers side brake lights at all times. I pulled the flasher module out and inspected it, I didn't see any noticable problem with it. So I put it back in and then the brake light started working again. Until I tested the blinkers and then no power to the drivers side brake light again. Then when I tapped on the fuse block the power came back on.
#369
Thanks!
FYI if anyone else happens to need one of these. When I looked it up on GM part direct they say the part number has been replaced with this one 10383321
#370
NO PROBLEM... IF YOU HAVE ANY OTHER QUESTIONS PLEASE FEEL FREE TO ASK... i AM WORKIN TODAY... AND i HAVE MY TRUCK ON THE LIFT CAUSE I DONT FEEL LIKE TOUCHING TAHT DAMN LS7
