Gm Part #anyone?
Old Jan 15, 2007 | 02:53 PM
  #351
I'm looking for GM replacement optional SLP muffler part # for a
1997 Camaro SS.
SLP Muffler, SLP # 31020 SS Replacement w/3" Inlet, 2 X 2-1/2" Outlet
[31020]
Can you still buy 2OTL muffler from GM ??
If so, anyone know the part #.
Thanks,
Dave
Old Jan 15, 2007 | 08:59 PM
  #352
bigredexpress99's Avatar
thats a tricky one.....if I remember right, back in the hayday of the Fbodies, SLP stuff was only available through SLP......hoods for SS's, exhaust systems, alot of other things.....
Old Jan 15, 2007 | 09:10 PM
  #353
Lurius's Avatar
Im looking for the part #'s associated with the paintable/painted front bumper cap for the 06 silverados. I tried searching but no luck. If they only come pre-painted then if you find one for paint code 62u i'd love it!
-Lurius
Old Jan 18, 2007 | 05:01 AM
  #354
I'm hoping that there is a GM part # as SLP doesn't have them anymore.
Maybe it's the 10 year rule , after 10 years after car is made vendor doesn't have to stock/make parts anymore ???
Old Jan 18, 2007 | 08:29 PM
  #355
CHEVRACER83's Avatar
-Lurius
89025820 MUST BE PAINTED THOUGH
THATS THE UPPER BUMPER CAP.... THAT IS ABOVE THE CHROME..... BELOW THE GRILLE
Old Jan 18, 2007 | 08:32 PM
  #356
WHAT IS THE VIN NUMBER FOR YOUR SS? OR SEND IT TO ME IN A PM.... I WILL TAKE A LOOK AROUND
1997 Camaro SS.
[31020]
Thanks,
Dave
Old Jan 18, 2007 | 10:40 PM
  #357
valsperformance's Avatar
Banned
Default The longer Flex plate bolts
The ones used with the spacer and 6.0 plate? Doing a 4l80 conversion and that is all that I need to install...
Old Jan 19, 2007 | 12:00 AM
  #358
negativeswitches's Avatar
GMC part number??????????
looking for a p/n for a paintable grille shell for the 99-02 sierra (i believe the paintable version was on the yukon???
p/n for a left and right valvecover assy. with bolts and seals for the lsx heads (4.8 or 5.3 or 5.7 or 6.0)
ls6 valley cover with pcv vent tube
ls6 sodium filled intake and exhaust valves (or was it jsut exhaust valve???... damn i forgot)
i also need a p/n for the 5 speed rear trans c-member for a 99 silverado NBS with a 4.8 (not the carrier bearing c-member)
thanks guys
Old Jan 19, 2007 | 10:49 PM
  #359
truckmann's Avatar
I would like to know the part number for the flasher/blinker relay module for the trailor light system on a 2003 Silverado.
Old Jan 20, 2007 | 09:37 AM
  #360
thanks guys
valve covers :
drv side: 12570427 (includes bolts, grommets and gasgets)
pass side: 12582224 (includes bolts, grommets and gasgets)
Manual trans crossmember
15741709
exhaust only is sodium filled valve:
12565312
non chrome gmc grille:
19130786 (may want to see part before purchase, make sure it is what you want) Im pretty sure this is what you are looking for.... same one as used on SIERRA C3
valley cover:
12568002
pcv tube assm:
12573109
