Gauge mount questions
100% Redneck
The plastic tiles clean up really easily with oil or trans fluid spills. The only thing that has stained the white tiles is brake dust when doing brake jobs. I have some extras to change out when they get damaged or stained.
I don't blame you for painting your A-pillar pod since it covers only a small portion of the factory A-pillar trim, I would've done that. I was talking about the steering wheel pod. My A-pillar pods (2 gauge) overlays the entire factory A-pillar trim, so I didn't bother painting it as well.
100% Redneck
Just a heads up... the SEM 17113 Graphite is a perfect match for my 2000 Sierra interior.
Washed the pod with prep-sol then scuffed with a scotch-brite pad. Washed the pod again (these parts have a release agent during manufacture that can cause fisheyes) with prep-sol. Masked off the exposed OEM A-Pillar then shot one very lite coat. Let it flash 10 minutes then followed with another lite coat. Let it flash 10 minutes then followed by a medium coat. Let flash 15 minutes then followed with a medium-wet coat.
Perfect match as I did not spray any of the OEM pillar
I found on some diesel sites, they have the column single/dual, up to 3 molded into the pillar, the airbag switch spot, overhead console and a few other spots. They had the best offerings i found. I even thought of mounting it in the driver ac vent and leaving some slots some how. This weelend im going to baton rouge to get a escalade console and associtated pieces, maybe make a mount inside it.
over head will be hard to see from outside
PLX Wideband DM-100 SM-AFR Universal Digital Display Module And Air/Fuel Sensor Module Combo Universal 2 1/16" (52mm) Gauge And Air/Fuel Sensor Module - Bosch Wideband Oxygen Sensor Type A - Autometer Phantom White Face Analog Clock Gauge #ATM-5785 - So-Cal Black Anodized Overhead Console Two Gauges Mount With Switches .
RedXray (08-31-2018)
