Gauge mount questions
Old Aug 26, 2018 | 05:13 PM
TurboJohn6's Avatar
To me, I didn't see the need to paint it. It's black, and everything around it is graphite with black accents. The instrument cluster face is mostly black. That's why I didn't bother painting mine.
Old Aug 26, 2018 | 05:18 PM
TurboJohn6's Avatar
Cool
By the way, I like your garage/man cave! Pretty cool, but I don't think I would be doing much work on my vehicles in there. I would be too worried about making a mess or stinking things up.
Old Aug 26, 2018 | 09:33 PM
CHRGDUP_Denali's Avatar
All AEM and look OEM
Edit: just realized it not the correct body style but you get the point. Doesn't affect my visibility but was distracting at first
Old Aug 27, 2018 | 02:48 AM
RedXray's Avatar
100% Redneck
Yeah the black pod doesn't really stand out that much against the pillar. When I ordered the pod I ordered the paint at the same time so I may as well spray it. The paint was ridiculously high at $16
Thanks but a little to late
The plastic tiles clean up really easily with oil or trans fluid spills. The only thing that has stained the white tiles is brake dust when doing brake jobs. I have some extras to change out when they get damaged or stained.
Old Aug 27, 2018 | 06:02 AM
TurboJohn6's Avatar
I don't blame you for painting your A-pillar pod since it covers only a small portion of the factory A-pillar trim, I would've done that. I was talking about the steering wheel pod. My A-pillar pods (2 gauge) overlays the entire factory A-pillar trim, so I didn't bother painting it as well.
Old Aug 27, 2018 | 10:09 PM
RedXray's Avatar
100% Redneck
Just a heads up... the SEM 17113 Graphite is a perfect match for my 2000 Sierra interior.
Washed the pod with prep-sol then scuffed with a scotch-brite pad. Washed the pod again (these parts have a release agent during manufacture that can cause fisheyes) with prep-sol. Masked off the exposed OEM A-Pillar then shot one very lite coat. Let it flash 10 minutes then followed with another lite coat. Let it flash 10 minutes then followed by a medium coat. Let flash 15 minutes then followed with a medium-wet coat.
Perfect match as I did not spray any of the OEM pillar
Old Aug 28, 2018 | 08:14 AM
NC03GT's Avatar
formerly projectLS10, 2014-09-01
I put mine along with my nitrous pressure gauge in the pocket in my headliner, I'll snap some pics when I get off
Old Aug 28, 2018 | 10:09 PM
arthursc2's Avatar
I hate the way those add-a pods look. Look like crap. I wish they still made pods integrated into the a pillar for us
Old Aug 30, 2018 | 06:54 PM
comeaux818's Avatar
5 Year Member
I found on some diesel sites, they have the column single/dual, up to 3 molded into the pillar, the airbag switch spot, overhead console and a few other spots. They had the best offerings i found. I even thought of mounting it in the driver ac vent and leaving some slots some how. This weelend im going to baton rouge to get a escalade console and associtated pieces, maybe make a mount inside it.
Old Aug 31, 2018 | 10:52 AM
shakesvho's Avatar
over head will be hard to see from outside
PLX Wideband DM-100 SM-AFR Universal Digital Display Module And Air/Fuel Sensor Module Combo Universal 2 1/16" (52mm) Gauge And Air/Fuel Sensor Module - Bosch Wideband Oxygen Sensor Type A - Autometer Phantom White Face Analog Clock Gauge #ATM-5785 - So-Cal Black Anodized Overhead Console Two Gauges Mount With Switches .
