gas cap lock broken..down to less than 1/4 tank help!
Old Jun 21, 2007 | 04:29 PM
2LEGIT's Avatar
Default gas cap lock broken..down to less than 1/4 tank help!
Man I am screwed by the end of tomorrow if I can't get this cap off. Locking cap, lock must be broken cause it just spins. Any Idea's as to how to get it the **** off. I hope I can make it home from school tomorrow lol.
Old Jun 21, 2007 | 04:52 PM
viciousknid's Avatar
Where's the Beef?
i know its wrong.. but...
That SUCKS. i don't have a clue how you would do it with out tearing up the hose.
Old Jun 21, 2007 | 05:37 PM
nonnieselman's Avatar
Dude you can crawl under the driver side of your truck and undo the filler neck... i think its got a hose clamp and 2 of them push pin things....
If you can get the whole assembly off then you can just disconnect the cap peice and fill your truck up... then put it all back together...
Yea it sounds like alot to do just to put gas in it,,, but hey i bet its alot harder to walk home
Old Jun 21, 2007 | 05:39 PM
I just went and looked at mine...
Your goin to need a Torx head bit... not sure.. prob a 25 or so.
And a flat head screw driver or a 5/16" nut driver. and i hope you can figure it out from there... just try not to drop any dirt or stuff into your filler neck hose..
Old Jun 21, 2007 | 10:52 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Hacksaw?
pull the filler neck and break that bitch off piece by piece. New cap is like $10.
Drill the lock right out and break the rest off.
Old Jun 21, 2007 | 10:54 PM
truckmann's Avatar
BFH!!!
Old Jun 21, 2007 | 11:50 PM
2LEGIT's Avatar
hahaha thanks for the ideas guys but i called parts n service n he said to use the biggest flat head screwdriver i could find lol. so i bashed that bitch into the key hole till it wouldn't go anymore and it came off... bunch of pieces flew off on the first wack n the rest was just me gettin pissed at it lol
Old Jun 22, 2007 | 02:52 AM
Spoolin's Avatar
GFYS and STFU
I hope no pieces dropped into the can?? Well I guess the check valve would of caught it anyways. Good job bro!
Old Jun 22, 2007 | 07:37 AM
SSSBLKOUT's Avatar
**** it, get the cutting torch
Old Jun 22, 2007 | 12:03 PM
Spoolin's Avatar
GFYS and STFU
LOL, What are you polish?? Drop a flare in there too to see how much gas you have left while your at it!!
