gains/losses with different wheel and tire setups
Old Nov 18, 2006 | 01:54 AM
TXsilverado's Avatar
Default gains/losses with different wheel and tire setups
i swapped to 18" eagle alloy 219's with nitto 404's (285/50-18) and lost almost 2/10'ths in my 60' times
my last setup was chevy oem 17's with 275/60 17 proxies. before on the 17's i would cut 1.18-2.21 60' times consistantly on the stock converter. after the trailblazer stall that dropped to 2.02 consistantly...swaped to the eagles which is a lighter wheel and more meat for tires and my 60' times drop to 2.18. does that sound right???
if i coulda gotten my 60's right i coulda broke into 13's on street tires tonight with the stock 5.3. instead im questioning if my wheels were really worth it
Old Nov 18, 2006 | 03:13 AM
TouchOfEvil04's Avatar
Hard to say really.How are track conditions compared to when you would cut the lower 60 times?
Also the more meat means more resistance.Plus the larger rim even though smaller can cause it to take an effect on your rotation per ya know what i mean.Maybe thats your problem?
Old Nov 18, 2006 | 07:47 AM
Moddoo's Avatar
You probably have more mass at a greater distance from the axis of rotation.=More energy to accelerate.
New larger tires and new larger wheels could hurt your times, even if the wheel is lighter than stock.
The obvious fix is a new larger Radix
Old Nov 18, 2006 | 07:58 AM
jakebdb56's Avatar
heh, yeah a radix would be fun.
hey TX where you at HRP last night? I was out there, but couldn't really tell who all from this board was out there since there's so many dropped chevy trucks out there.
IMO I'd just get some light 16" cragars or something and some smaller tires.
Old Nov 18, 2006 | 10:13 AM
ThunderZ28's Avatar
12 Second Club
The track sucked last night..
even with slicks it was hard to get traction..
I was all over the place.
Old Nov 18, 2006 | 10:39 AM
nightrunner's Avatar
Mr. Obvious
i would cut 1.18 60' times consistantly on the stock converter
damn i wouldnt be complaining about 1.18 60' times espeially on stock tc
Old Nov 18, 2006 | 10:40 AM
jakebdb56's Avatar
wasn't that bad until later in the evening when it got real cold. I got there when it was still barely daylight and ran in the first few rounds. I only spun just a little the last run I made right when it got cold as *****.
Old Nov 18, 2006 | 11:32 AM
we went to the track in sealey...wont make that mistake again. theres no pit area, you cant drive around the water box, traction sucked, it was a bit of a pain in the *** to get to the time slip booth without power steering etc etc...the one good thing is that you could pretty much do laps nascar style. maybe meatwad will swap rear tires with me and we can both make passes on each others wheel and tire combos and check out how each others 60' times change. he's the one who bought my old wheels and tires.
BoostedBowTie
Jan 3, 2020 06:46 PM
Steve-O-08
Apr 19, 2018 09:32 AM
JordanH
Aug 8, 2015 07:59 PM
Ketis
Jul 23, 2015 12:37 PM
03sierraslt
Jul 11, 2015 02:47 PM
