Fuel pump replacement - Racetronix in 2000 Silverado
Old Dec 11, 2010 | 05:27 PM
dsmwookie's Avatar
Default Fuel pump replacement - Racetronix in 2000 Silverado
The OEM pumps are expensive as hell and I can't justify that with Walboro pumps being so cheap an accessible. From what I have read I can use the following:
http://www.racetronix.biz/itemdesc.a...PA-007&eq=&Tp=
http://www.racetronix.biz/itemdesc.a...%2D016&eq=&Tp=
http://www.racetronix.biz/itemdesc.a...%2D001&eq=&Tp=
I read a few write ups and it seems like one of these will work with little modification. I m not trying to be a cheap ***, but $340 for a delphi pump is ridiculously overpriced.
Are there any ill effects of putting a performance pump in a stock truck? Will it overrun the fuel pressure regulator? Etc...
If you have any questions about my application let me know. It is a bone stock 5.3L, 2000 Z71 Extended cab.
Old Dec 11, 2010 | 06:07 PM
Atomic's Avatar
I have a gauge for that
You will be fine with a bigger pump like the walbro.
Old Dec 11, 2010 | 06:34 PM
dsmwookie's Avatar
Awesome thanks man!
The $150 Racetronix pump is a drop in affair correct?
Old Dec 12, 2010 | 06:10 PM
dsmwookie's Avatar
Bueller?
Here are some pictures of my pump assembly. For some reason my OEM pump does not have the nipple on it for a venturi style? What do I do in this case?
Leave the nipple open and let it ride?
5.3Okasai
Mar 9, 2022 01:07 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
wrb002
Aug 31, 2015 12:00 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
