Which flexplate to use for 4L80E
Old Oct 6, 2005 | 09:55 PM
Blackdog76's Avatar
Default Which flexplate to use for 4L80E
I got a 6.0l project going and I just bought a 4L80E to match but the flexplate doesn't mate up to the 4L80E. Do I need a 4L80E specific flex plate? When I checked the summit website they only list one flexplate for the LS1 and LQ4 truck motor.
Old Oct 6, 2005 | 10:58 PM
quicksilverado's Avatar
Lq4 is a 6.0 it should work.
Old Oct 7, 2005 | 01:12 PM
Blackdog76's Avatar
The flexplate that came with my motor was a stock flexplate. It probably had the 4L60E transmission. I am using a 4L80E. Is there a difference in flexplates? If not, why won't it bolt up?
Old Oct 7, 2005 | 02:27 PM
Yellowsierra's Avatar
THe flexplate jegs sells has both 4l60e and 4l80e bolt holes drilled in it. You can get you flexplate to work but will have to take it to a machine shop to drill the holes for you.
Old Oct 8, 2005 | 05:03 PM
Blackdog76's Avatar
Found one on GM parts direct for the 4L80E. Thanks
Old Oct 8, 2005 | 10:30 PM
Nick's Avatar
share the part # while you're at it!
Old Oct 8, 2005 | 11:26 PM
It depends on which converter you plan to use.My Vigilante is setup to use a 4L60E flexplate.The Yank I use before used a 4L80E flexplate from a 01 HD.The spacing is different on the 2 different flexplates so you'll need to know what the converter is setup for.
Old Oct 8, 2005 | 11:37 PM
My Art Carr has 3 different holes on each mounting point. It will work with both flex plates.
RustyD
May 23, 2016 07:04 PM
AdaMax
May 16, 2016 11:35 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
turbo6c3
Oct 5, 2015 06:11 PM
jscherbs
Sep 30, 2015 07:54 AM
