et streets with stock 16's
Ive got some et streets mounted on stock 16's with tubes. Im twisting the tubes up so that I cant get to the valve stems what are yall doing to keep the tires from spinning on the wheels?
9 Second Truck Club
You are spinning the wheel in the tire. Sometimes that is caused by the tire shop using lube under the beed, don't let them use that crap. I glue the beeds and don't run the tubes. If you're running really low air psi you might have to screw the tire to the wheel. Slummit sells the screw kit.
BennyB
08-01-2015 08:48 AM
